楼主: zxw
求助!!!关于属性块炸开后的错误
发表于 2013-1-21 21:38:27 | 显示全部楼层
zxw 发表于 2003-12-27 15:59
请教BDYCAD老兄!
burst 是未知命令
BURST是CAD默认的express tools工具下的二次开发命令,你一定是自定义安装的时候没有完全安装。
发表于 2021-6-25 07:27:08 | 显示全部楼层
;;;    BURST.LSP
;;;    Copyright ?1999-2006 by Autodesk, Inc.
;;;    Your use of this software is governed by the terms and conditions of the
;;;    License Agreement you accepted prior to installation of this software.
;;;    Please note that pursuant to the License Agreement for this software,
;;;    "[c]opying of this computer program or its documentation except as
;;;    permitted by this License is copyright infringement under the laws of
;;;    your country.  If you copy this computer program without permission of
;;;    Autodesk, you are violating the law."
;;;    AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;;    AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;;    MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
;;;    DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;;    UNINTERRUPTED OR ERROR FREE.
;;;    Use, duplication, or disclosure by the U.S. Government is subject to
;;;    restrictions set forth in FAR 52.227-19 (Commercial Computer
;;;    Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;;    (Rights in Technical Data and Computer Software), as applicable.
(Defun C:BURST (/ item bitset bump att-text lastent burst-one burst
                  BCNT BLAYER BCOLOR ELAST BLTYPE ETYPE PSFLAG ENAME )
   ; Item from association list
   (Defun ITEM (N E) (CDR (Assoc N E)))
   ; Error Handler
  (acet-error-init
    (list
      (list "cmdecho" 0
            "highlight" 1
      T     ;flag. True means use undo for error clean up.
    );list
  );acet-error-init
   ; BIT SET
   (Defun BITSET (A B) (= (Boole 1 A B) B))
   ; BUMP
   (Setq bcnt 0)
   (Defun bump (prmpt)
      (Princ
         (Nth bcnt '("\r-" "\r\\" "\r|" "\r/"))
      (Setq bcnt (Rem (1+ bcnt) 4))
   ; Convert Attribute Entity to Text Entity or MText Entity
   (Defun ATT-TEXT (AENT / ANAME TENT ILIST INUM)
      (setq ANAME (cdr (assoc -1 AENT)))
      (if (_MATTS_UTIL ANAME)
            ; Multiple Line Text Attributes (MATTS) -
            ; make an MTEXT entity from the MATTS data
            (_MATTS_UTIL ANAME 1)
            ; else -Single line attribute conversion
            (Setq TENT '((0 . "TEXT")))
            (ForEach INUM '(8
                            6
                            38
                            39
                            62
                            67
                            210
                            10
                            40
                            1
                            50
                            41
                            51
                            7
                            71
                            72
                            73
                            11
                            74
               (If (Setq ILIST (Assoc INUM AENT))
                   (Setq TENT (Cons ILIST TENT))
            (Setq
               tent (Subst
                       (Cons 73 (item 74 aent))
                       (Assoc 74 tent)
                       tent
            (EntMake (Reverse TENT))
   ; Find True last entity
   (Defun LASTENT (/ E0 EN)
      (Setq E0 (EntLast))
      (While (Setq EN (EntNext E0))
         (Setq E0 EN)
      E0
   ; See if a block is explodable. Return T if it is,
   ; otherwise return nil
   (Defun EXPLODABLE (BNAME / B expld)
      (vl-load-com)
      (setq BLOCKS (vla-get-blocks
                     (vla-get-ActiveDocument (vlax-get-acad-object)))
      (vlax-for B BLOCKS (if (and (= :vlax-false (vla-get-islayout B))
                                  (= (strcase (vla-get-name B)) (strcase BNAME)))
                      (setq expld (= :vlax-true (vla-get-explodable B)))
       expld
   ; Burst one entity
   (Defun BURST-ONE (BNAME / BENT ANAME ENT ATYPE AENT AGAIN ENAME
                     ENT BBLOCK SS-COLOR SS-LAYER SS-LTYPE mirror ss-mirror
                     mlast)
      (Setq
         BENT   (EntGet BNAME)
         BLAYER (ITEM 8 BENT)
         BCOLOR (ITEM 62 BENT)
         BBLOCK (ITEM 2 BENT)
         BCOLOR (Cond
                   ((> BCOLOR 0) BCOLOR)
                   ((= BCOLOR 0) "BYBLOCK")
                   ("BYLAYER")
         BLTYPE (Cond ((ITEM 6 BENT)) ("BYLAYER"))
      (Setq ELAST (LASTENT))
      (If (and (EXPLODABLE BBLOCK) (= 1 (ITEM 66 BENT)))
         (Progn
            (Setq ANAME BNAME)
            (While (Setq
                      ANAME (EntNext ANAME)
                      AENT  (EntGet ANAME)
                      ATYPE (ITEM 0 AENT)
                      AGAIN (= "ATTRIB" ATYPE)
               (bump "正在转换属性")
               (ATT-TEXT AENT)
         (Progn
            (bump "分解块")
            (acet-explode BNAME)
            ;(command "_.explode" bname)
      (Setq
         SS-LAYER (SsAdd)
         SS-COLOR (SsAdd)
         SS-LTYPE (SsAdd)
         ENAME    ELAST
      (While (Setq ENAME (EntNext ENAME))
         (bump "收集片")
         (Setq
            ENT   (EntGet ENAME)
            ETYPE (ITEM 0 ENT)
         (If (= "ATTDEF" ETYPE)
            (Progn
               (If (BITSET (ITEM 70 ENT) 2)
                  (ATT-TEXT ENT)
               (EntDel ENAME)
            (Progn
               (If (= "0" (ITEM 8 ENT))
                  (SsAdd ENAME SS-LAYER)
               (If (= 0 (ITEM 62 ENT))
                  (SsAdd ENAME SS-COLOR)
               (If (= "BYBLOCK" (ITEM 6 ENT))
                  (SsAdd ENAME SS-LTYPE)
      (If (> (SsLength SS-LAYER) 0)
         (Progn
            (bump "固定图层")
            (Command
               "_.chprop" SS-LAYER "" "_LA" BLAYER ""
      (If (> (SsLength SS-COLOR) 0)
         (Progn
            (bump "固定颜色")
            (Command
               "_.chprop" SS-COLOR "" "_C" BCOLOR ""
      (If (> (SsLength SS-LTYPE) 0)
         (Progn
            (bump "固定线型")
            (Command
               "_.chprop" SS-LTYPE "" "_LT" BLTYPE ""
   ; BURST MAIN ROUTINE
   (Defun BURST (/ SS1)
      (setq PSFLAG (if (= 1 (caar (vports)))
                       1 0
      (Setq SS1 (SsGet (list (cons 0 "INSERT")(cons 67 PSFLAG))))
      (If SS1
         (Progn
            (Setvar "highlight" 0)
            (terpri)
            (Repeat
               (SsLength SS1)
               (Setq ENAME (SsName SS1 0))
               (SsDel ENAME SS1)
               (BURST-ONE ENAME)
            (princ "\n")
   ; BURST COMMAND
   (BURST)
  (acet-error-restore)
);end defun
GMT+8, 2025-5-2 09:44 , Processed in 0.153308 second(s), 17 queries , Gzip On.
