查看: 3222|回复: 5
(求助)块属性提取
发表于 2003-12-18 12:07:00 | 显示全部楼层 |阅读模式
怎样提取块的插入点坐标??
下面的程序可以提取快标记和属性值
望大侠帮忙修改一下,可以提取插入点坐标
谢谢!!
Sub Ch12_Extract()
    Dim Excel As Excel.Application
    Dim ExcelSheet As Object
    Dim ExcelWorkbook As Object
    Dim RowNum As Integer
    Dim Header As Boolean
    Dim elem As AcadEntity
    Dim Array1 As Variant
    Dim Count As Integer
    ' 启动 Excel。
    Set Excel = New Excel.Application
    ' 创建新的工作簿并查找活动电子表格。
    Set ExcelWorkbook = Excel.Workbooks.Add
    Set ExcelSheet = Excel.ActiveSheet
    ExcelWorkbook.SaveAs "Attribute.xls"
    RowNum = 1
    Header = False
    ' 遍历模型空间,查找
    ' 所有的块引用。
    For Each elem In ThisDrawing.ModelSpace
        With elem
            ' 找到块引用时,
            ' 检查其属性
            If StrComp(.EntityName, "AcDbBlockReference", 1) _
                = 0 Then
                If .HasAttributes Then
                    ' 获取属性
                    Array1 = .GetAttributes
                    ' 将属性的标记字符串
                    ' 复制到 Excel
                    For Count = LBound(Array1) To UBound(Array1)
                        If Header = False Then
                            If StrComp(Array1(Count).EntityName, _
                                  "AcDbAttribute", 1) = 0 Then
                                ExcelSheet.Cells(RowNum, _
                                    Count + 1).value = _
                                    Array1(Count).TagString
                            End If
                        End If
                    Next Count
                    RowNum = RowNum + 1
                        ExcelSheet.Cells(RowNum, Count + 1).value = Array1(Count).TextString
                    Next Count
                    Header = True
                End If
            End If
        End With
    Next elem
    Excel.Application.Quit
End Sub
发表于 2003-12-18 13:48:00 | 显示全部楼层
  1. dim v as variant
  2. For Each elem In ThisDrawing.ModelSpace
  3.         With elem
  4.            If StrComp(.EntityName, "AcDbBlockReference", 1)  = 0 Then
  5.                v=.InsertionPoint
  6.                 ExcelSheet.Cells(RowNum,  1).value = v(0)
  7.                 ExcelSheet.Cells(RowNum,  2).value = v(1)
  8.                 ExcelSheet.Cells(RowNum,  3).value = v(2)
  9.                 RowNum = RowNum + 1
  10.             End If
  11.          End With
  12.     Next elem
复制代码
 楼主| 发表于 2003-12-18 13:41:00 | 显示全部楼层
自己顶
 楼主| 发表于 2003-12-19 16:08:00 | 显示全部楼层
thanks
GMT+8, 2025-7-4 05:51 , Processed in 0.196245 second(s), 24 queries , Gzip On.
