查看: 1688|回复: 4
Arx图层问题,困惑几天了。
发表于 2003-12-1 12:00:00 | 显示全部楼层 |阅读模式
提一个很菜的问题。
我在ARX程序中新建了一个图层,怎样在程序中将其设置为当前层?
发表于 2003-12-1 13:02:00 | 显示全部楼层
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=12132
发表于 2003-12-2 17:07:00 | 显示全部楼层
参考:
void createNewLayer(char* lyrname, Adesk::UInt16 clr, AcDbObjectId ltypeId, Adesk::Boolean current)
        // We need to check if the layer name exists
        // If the layer name exists, apply the color
        // linetype id and whither to make it current
        // or not. In order to be current it cannot be
        // frozen, so we need to check for this also.
        // If the layer name does not exist we just create
        // a new layer with the properties contained in the arguments
        AcDbLayerTable *pLyrTable;
        AcDbLayerTableRecord *pLyrTblRecord;
        AcDbObjectId recId;
        AcCmColor color;
        color.setColorIndex(clr); // set color to parameter clr
        AcDbDatabase *pCurDb = NULL;
        pCurDb = acdbHostApplicationServices()->workingDatabase();
        pCurDb->getLayerTable(pLyrTable, AcDb::kForRead);
        // Check to see if the layer name exists
        if(pLyrTable->has(lyrname))
                pLyrTable->getAt(lyrname, pLyrTblRecord, AcDb::kForWrite, Adesk::kFalse);
                // pLyrTblRecord now points at the layer table record
                // which was opened for write
                pLyrTblRecord->setIsFrozen(Adesk::kFalse);
                pLyrTblRecord->setColor(color);
                pLyrTblRecord->setLinetypeObjectId(ltypeId);
        else
                // Note how we can change the open mode
                // of the layer table from AcDb::kForRead
                // to AcDb::kForWrite
                pLyrTable->upgradeOpen();
                pLyrTblRecord = new AcDbLayerTableRecord;
                pLyrTblRecord->setName(lyrname);
                pLyrTable->add(pLyrTblRecord);
        // Get the layer Table ObjectId
        recId = pLyrTblRecord->objectId();
        pLyrTblRecord->close();
        pLyrTable->close();
        // Set the layer current if current
        // is equal to Adesk::kTrue
        // pCurDb is point to the current
        // drawing database
        // The database AcDbDatabase has a number of
        // query and edit functions for the header variables
        if(current)
                pCurDb->setClayer(recId);
发表于 2003-12-2 17:08:00 | 显示全部楼层
 楼主| 发表于 2003-12-8 10:42:00 | 显示全部楼层
谢谢,使用setVar已经解决了。
GMT+8, 2025-5-11 11:31 , Processed in 0.164726 second(s), 25 queries , Gzip On.
