查看: 2669|回复: 1
[VBA]输入弧形长度旋转复制物体
发表于 2003-11-18 17:00:00 | 显示全部楼层 |阅读模式
Sub a1()
On Error Resume Next
Dim obj As AcadObject
Dim P1 As Variant
ThisDrawing.Utility.GetEntity obj, P1, vbCrLf & "请选择要复制的物体:"
If Err Then Exit Sub
Dim cenpnt As Variant
Dim r As Double
cenpnt = ThisDrawing.Utility.GetPoint(, "请选取圆心")
r = ThisDrawing.Utility.GetDistance(cenpnt, "请输入半径:")
Dim dist, du As Double
Dim n As Integer
n = 0
Do While n < 1
   n = ThisDrawing.Utility.GetInteger("请输入复制个数:")
Loop
dist = ThisDrawing.Utility.GetReal("请输入旋转距离:")
du = dist / r
Dim i As Integer
For i = 1 To n
   Set obj = obj.Copy
   obj.Rotate cenpnt, du
Next
End Sub
发表于 2011-6-18 11:55:20 | 显示全部楼层
好东东,学习了~~
GMT+8, 2025-5-25 02:31 , Processed in 0.155020 second(s), 23 queries , Gzip On.
