查看: 16181|回复: 32
[分享]坡度标注程序
发表于 2003-11-9 21:30:00 | 显示全部楼层 |阅读模式
有个朋友要坡度标注的功能,所以帮他做了,感觉还是很顺利。
  现共享出来与大家分享。如果有更好的建议或者批评指正,欢迎提出。在此感谢
  源码如下:
'2003.10.9
'by gzy
'www.mjtd.com
'Email:gzy@mjtd.com
Public jd, h As Double
Sub mainmenu()
Dim newmenu As AcadPopupMenu
Dim newmenugroup As AcadMenuGroup
Dim newmenuitemname As AcadPopupMenuItem
Set newmenugroup = ThisDrawing.Application.MenuGroups.Item(0)
Set newmenu = newmenugroup.Menus.Add("坡度标注")
Set newmenuitemname = newmenu.AddMenuItem(newmenu.Count + 0, "相对X轴坡度", "-vbarun pd ")
Set newmenuitemname = newmenu.AddMenuItem(newmenu.Count + 1, "相对指定直线坡度", "-vbarun rj ")
Set newmenuitemname = newmenu.AddMenuItem(newmenu.Count + 2, "退出坡度标注程序", "-vbarun u2 ")
newmenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.Count + 1)
End Sub
Sub u2()
ThisDrawing.SendCommand "filedia 0 "
ThisDrawing.SendCommand "menu " + Chr(13)
ThisDrawing.SendCommand "filedia 1 "
End Sub
Sub pd()
Dim lineobj As AcadLine
Dim selobj As AcadObject, selpnt As Variant
Dim mp1(0 To 2) As Double
Dim mp2(0 To 2) As Double
RETRY:
On Error Resume Next
Do While code = 0
ThisDrawing.Utility.GetEntity selobj, selpnt, "请选择目标直线"
If Err <> 0 Then
        Err.Clear
        ThisDrawing.Utility.Prompt " 没有选定对象,退出"
        Exit Sub
    End If
If Err.Number = 0 Then
If (selobj.EntityName = "AcDbLine") Then
  Set lineobj = selobj
  mp1(0) = lineobj.StartPoint(0)
  mp1(1) = lineobj.StartPoint(1)
  mp2(0) = lineobj.EndPoint(0)
  mp2(1) = lineobj.EndPoint(1)
Exit Do
End If
Else
Err.Clear
  End If
  Loop
Dim i As Double
i = (mp2(1) - mp1(1)) / (mp2(0) - mp1(0))
Dim a
Dim textobj As AcadText
Dim textstring As String
Dim inspoint(0 To 2) As Double
Dim textheight As Double
UserForm1.Show
If i > 0 Then
  If i > 1 Then
  a = Mid(LTrim(Str(i)), 1, jd + 2)
  textstring = "i=" & a
  Else
  a = Mid(LTrim(Str(i)), 1, jd + 1)
  textstring = "i=0" & a
  End If
Else
  If Abs(i) > 1 Then
    a = Mid(LTrim(Str(i)), 2, jd + 2)
  End If
  If Abs(i) < 1 Then
    a = Mid(LTrim(Str(i)), 2, jd + 1)
  End If
End If
Dim pin As Variant
pin = ThisDrawing.Utility.GetPoint(, vbCrLf & "请输入插入点:")
inspoint(0) = pin(0)
inspoint(1) = pin(1)
inspoint(2) = pin(2)
textheight = h    '此处可修改文字高度
If i = 0 Then
  textstring = "i=0"
  End If
Set textobj = ThisDrawing.ModelSpace.AddText(textstring, inspoint, textheight)
Dim rotateangle As Double
rotateangle = Atn(i)
textobj.Rotate inspoint, rotateangle
GoTo RETRY
End Sub
Sub rj()
Dim lineobj(0 To 1) As AcadLine
Dim mp3(0 To 2) As Double
Dim mp4(0 To 2) As Double
RETRY:
Do While code = 0
If Err <> 0 Then
        Err.Clear
        Exit Sub
    End If
  Set lineobj(0) = selobj
  mp1(0) = lineobj(0).StartPoint(0)
  mp1(1) = lineobj(0).StartPoint(1)
  mp2(0) = lineobj(0).EndPoint(0)
  mp2(1) = lineobj(0).EndPoint(1)
  Dim x1, y1, x2, y2 As Double
  x1 = mp2(0) - mp1(0)
  y1 = mp2(1) - mp1(1)
  Dim aha1, aha2 As Double
  aha1 = Atn(y1 / x1)
Exit Do
End If
Else
Err.Clear
  End If
  Loop
Do While code = 0
ThisDrawing.Utility.GetEntity selobj, selpnt, "请选择相对直线"
If Err <> 0 Then
        Err.Clear
        Exit Sub
End If
  Set lineobj(1) = selobj
  mp3(0) = lineobj(1).StartPoint(0)
  mp3(1) = lineobj(1).StartPoint(1)
  mp4(0) = lineobj(1).EndPoint(0)
  mp4(1) = lineobj(1).EndPoint(1)
   x2 = mp4(0) - mp3(0)
  y2 = mp4(1) - mp3(1)
  aha2 = Atn(y2 / x2)
Exit Do
End If
Else
   Err.Clear
End If
  Loop
  Dim i As Double
  i = Tan(aha1 - aha2)
Dim a
UserForm1.Show
If i > 0 Then
  If i > 1 Then
  Else
  End If
Else
  If Abs(i) > 1 Then
  End If
  If Abs(i) < 1 Then
  End If
End If
Dim pin As Variant
textheight = h
If i = 0 Then
  textstring = "i=0"
End If
rotateangle = Atn(y1 / x1)
GoTo RETRY
End Sub
Private Sub CommandButton1_Click()
UserForm1.Hide
jd = TextBox1.Text
h = TextBox2.Text
End Sub
Private Sub UserForm_Initialize()
'填写精度控制框的内容
TextBox1.Text = "2"
  TextBox2.Text = "5"
End Sub
发表于 2003-11-9 22:16:00 | 显示全部楼层
怎么用啊?????
 楼主| 发表于 2003-11-9 22:20:00 | 显示全部楼层
呵呵,运行模块里的菜单,这时CAD菜单上就会有相应的菜单(最后一项)
  这时选择后就可以直接用了。
发表于 2003-11-9 22:22:00 | 显示全部楼层
我是新手,文件下载了,但不知道放在哪??用法请说详细一点好吗?谢谢!
 楼主| 发表于 2003-11-9 22:27:00 | 显示全部楼层
工具——宏——加载工程:选择下载的程序
然后ALT+F11。如下图所示,
把鼠标停留在中间那个框处运行
发表于 2003-11-9 22:29:00 | 显示全部楼层
哦!谢谢
我试试^_^
发表于 2003-11-10 01:36:00 | 显示全部楼层
按你的方法加载了,但用不了啊,急死了
 楼主| 发表于 2003-11-10 09:14:00 | 显示全部楼层
怎么用不了?可能是你不懂怎么操作
发表于 2003-11-10 09:23:00 | 显示全部楼层
可以用了。不过有一个小问题。
使用“退出坡度标注程序”时把我自己做的所有菜单文件都自动卸载了。
 楼主| 发表于 2003-11-10 09:41:00 | 显示全部楼层
呵呵,这个问题我也没有办法改进了。
GMT+8, 2025-5-24 21:44 , Processed in 0.211477 second(s), 26 queries , Gzip On.
