查看: 1502|回复: 0
为何例程ents可以这样声名函数?
发表于 2003-10-31 21:43:00 | 显示全部楼层 |阅读模式
#include <string.h>
#include <aced.h>
#include <dbents.h>
#include <dbsymtb.h>
#include <dbgroup.h>
#include <dbapserv.h>
#include "dbfcf.h"
AcDbObjectId createLine();
AcDbObjectId createCircle();
void createNewLayer();
void createGroup();                             //问一:为何例程可以这样声名函数?
//而下面的函数体这样实现?带两个参数都不报错?
//void createGroup(AcDbObjectIdArray& objIds, char* pGroupName)
AcDbObjectId createFcf();
Acad::ErrorStatus changeColor(AcDbObjectId, Adesk::UInt16);
//        double point[3]={9.0, 3.0, 0.0};
//        AcDbFcf *pLine;
        AcGePoint3d center(90, 3.0, 0.0);
AcDbFcf *pLine = new AcDbFcf();
pLine->setText("{\\Fgdt;a}%%v0.1%%v%%v%%v%%v");
pLine->setLocation(center);
        AcDbBlockTable *pBlockTable;
    acdbHostApplicationServices()->workingDatabase()
        ->getSymbolTable(pBlockTable, AcDb::kForRead);
    AcDbBlockTableRecord *pBlockTableRecord;
    pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord,
        AcDb::kForWrite);
    pBlockTable->close();
    AcDbObjectId lineId;
    pBlockTableRecord->appendAcDbEntity(lineId, pLine);
    pBlockTableRecord->close();
    pLine->close();
return lineId;
// THE FOLLOWING CODE APPEARS IN THE SDK DOCUMENT.
AcDbObjectId
createLine()
    AcGePoint3d startPt(4.0, 2.0, 0.0);
    AcGePoint3d endPt(10.0, 7.0, 0.0);
    AcDbLine *pLine = new AcDbLine(startPt, endPt);
        AcDb::kForWrite);
    pLine->close();
    return lineId;
AcDbObjectId
createCircle()
    AcGePoint3d center(9.0, 3.0, 0.0);
    AcGeVector3d normal(0.0, 0.0, 1.0);
    AcDbCircle *pCirc = new AcDbCircle(center, normal, 2.0);
        AcDb::kForWrite);
    AcDbObjectId circleId;
    pBlockTableRecord->appendAcDbEntity(circleId, pCirc);
    pCirc->close();
    return circleId;
void
createNewLayer()
    AcDbLayerTable *pLayerTable;
        ->getSymbolTable(pLayerTable, AcDb::kForWrite);
    AcDbLayerTableRecord *pLayerTableRecord =
        new AcDbLayerTableRecord;
    pLayerTableRecord->setName("ASDK_MYLAYER");
        // Defaults are used for other properties of
        // the layer if they are not otherwise specified.
        pLayerTable->add(pLayerTableRecord);
    pLayerTable->close();
    pLayerTableRecord->close();
Acad::ErrorStatus
changeColor(AcDbObjectId entId, Adesk::UInt16 newColor)
    AcDbEntity *pEntity;
    acdbOpenObject(pEntity, entId,
        AcDb::kForWrite);
    pEntity->setColorIndex(newColor);
    pEntity->close();
    return Acad::eOk;
void
    AcDbGroup *pGroup = new AcDbGroup(pGroupName);
    for (int i = 0; i < objIds.length(); i++) {
        pGroup->append(objIds);
    // Put the group in the group dictionary which resides
    // in the named object dictionary.
    AcDbDictionary *pGroupDict;
        ->getGroupDictionary(pGroupDict, AcDb::kForWrite);
    AcDbObjectId pGroupId;
    pGroupDict->setAt(pGroupName, pGroup, pGroupId);
    pGroupDict->close();
    pGroup->close();
// END CODE APPEARING IN SDK DOCUMENT.
void
runIt()
    createNewLayer();
    AcDbObjectIdArray idArr;
    // create a line and circle and add them to the objectId
    // array
    idArr.append(createLine());
    idArr.append(createCircle());
        idArr.append(createFcf());
    // change circle color to red
    changeColor(idArr.last(), 1);
    createGroup(idArr, "ASDK_TEST_GROUP");
void initApp()
    acedRegCmds->addCommand("ASDK_MAKE_ENTS",
                            "ASDK_MKENTS",
                            "MKENTS",
                            ACRX_CMD_MODAL,
                            runIt);
void unloadApp()
        acedRegCmds->removeGroup("ASDK_MAKE_ENTS");
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
        switch (msg) {
        case AcRx::kInitAppMsg:
                       acrxDynamicLinker->unlockApplication(appId);
                                acrxDynamicLinker->registerAppMDIAware(appId);
                initApp();
                break;
        case AcRx::kUnloadAppMsg:
                unloadApp();
        return AcRx::kRetOK;
GMT+8, 2025-5-13 23:26 , Processed in 0.189274 second(s), 23 queries , Gzip On.
