查看: 3678|回复: 4
以指定長度創建一條与已知線段平行的線段,類似OFFSET(等距線)命令。
发表于 2003-10-26 12:35:00 | 显示全部楼层 |阅读模式
发表于 2003-10-28 11:43:00 | 显示全部楼层
;;parline.lsp
;;以指定长度创建一条与已知线段平行的线段,类似OFFSET(等距线)命令。
;;再简化
(defun C:PARLINE (/          HOLDECHO          HOLDOSMODE          D
                  L          PICK          ENT          TYPE1          TYPE2          ENT1
                  PT2          NEWENT  P1          P2
  (setq HOLDECHO (getvar "cmdecho"))
  (setq HOLDOSMODE (getvar "osmode"))
  (setvar "cmdecho" 0)
  (setvar "osmode" 0)
  (setq D (getreal "\n输入偏移距离: "))
  (setq L (getreal "\n输入新的实体长度: "))
  (setq PICK (entsel "\n拾取要偏移的对象:  "))
  (setq ENT (car PICK))
  (setq TYPE1 (entget (car PICK)))
  (setq ENT1 (cdr (assoc 0 TYPE1)))
  (if (= ENT1 "LINE")
      (setq PT2 (getpoint "\n往哪边偏移: "))
      (command "offset" D ENT PT2 "")
      (setq NEWENT (entlast))
      (setq TYPE2 (entget NEWENT))
      (setq P1 (cdr (assoc 10 TYPE2)))
      (setq P2 (cdr (assoc 11 TYPE2)))
      (command "_.scale"
               NEWENT
               (mapcar '/ (mapcar '+ P1 P2) '(2 2 2))
               (/ L (distance P1 P2))
    (prompt "\n该实体不是一条线!")
  (setvar "osmode" HOLDOSMODE)
  (setvar "cmdecho" HOLDECHO)
(prompt "\n键入PARLINE唤起命令: ")
 楼主| 发表于 2003-11-6 08:32:00 | 显示全部楼层
龍龍仔寫的好 !
发表于 2008-5-6 19:29:00 | 显示全部楼层
顶龙龙仔
发表于 2013-6-27 20:20:50 | 显示全部楼层
谢谢分享,学习一下
GMT+8, 2025-5-25 01:22 , Processed in 0.193324 second(s), 25 queries , Gzip On.
