查看: 4126|回复: 10
大大的问题
发表于 2002-2-28 19:01:00 | 显示全部楼层 |阅读模式
1、请问把文字做成三维的怎么做最快捷?
2、我不知道打印三维效果图?我把三维图画出来了,但打印时只打印出三维线框图,请大虾帮忙!!
发表于 2002-3-1 00:27:00 | 显示全部楼层
文字做三维,要把文字炸开
你可使用Express工具中的功能来炸开文字,做后就可以做三维了。
至于打印三维图,可以在渲染对话框中选择产生到渲染器中,然后在渲染器中打印。
发表于 2002-3-1 12:35:00 | 显示全部楼层
3DTEXT2.LSP for AutoCAD R14 ONLY
[zip]uploadImages/20023112351453803.zip[/zip]
发表于 2002-3-1 16:14:00 | 显示全部楼层
3D_TEXT.LSP FOR AUTOCAD2000
;;;    修改EXPRESSTOOL中的TXTEXP.LSP使用 By:赖云龙
;;;    虽配合EXPRESSTOOL
;;;    By Dominic Panholzer
;;;    TXTEXP.LSP
;;;    Copyright ?1999 by Autodesk, Inc.
;;;    Your use of this software is governed by the terms and conditions of the
;;;    License Agreement you accepted prior to installation of this software.
;;;    Please note that pursuant to the License Agreement for this software,
;;;    "[c]opying of this computer program or its documentation except as
;;;    permitted by this License is copyright infringement under the laws of
;;;    your country.  If you copy this computer program without permission of
;;;    Autodesk, you are violating the law."
;;;    AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;;    AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;;    MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
;;;    DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;;    UNINTERRUPTED OR ERROR FREE.
;;;    Use, duplication, or disclosure by the U.S. Government is subject to
;;;    restrictions set forth in FAR 52.227-19 (Commercial Computer
;;;    Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;;    (Rights in Technical Data and Computer Software), as applicable.
;;;  External Functions:
;;;     ACET-ERROR-INIT           --> ACETUTIL.FAS   Intializes bonus error routine
;;;     ACET-ERROR-RESTORE        --> ACETUTIL.FAS   Restores old error routine
;;;     ACET-GEOM-ZOOM-FOR-SELECT --> ACETUTIL.FAS   Zoom boundry to include points given
;;;     ACET-LAYER-LOCKED         --> ACETUTIL.FAS   Checks to see if layer is locked
;;;     ACET-GEOM-PIXEL-UNIT      --> ACETUTIL.FAS   Size of pixel in drawing units
;;;     ACET-GEOM-TEXTBOX         --> ACETUTIL.FAS   Returns the textbox for any text
;;;     ACET-GEOM-MIDPOINT        --> ACETUTIL.FAS   Returns midpoint between two points
;;;     ACET-GEOM-VIEW-POINTS     --> ACETUTIL.FAS   Returns corner points of screen or viewport
;;;     ACET-STR-FORMAT           --> ACETUTIL.ARX   String builder
;;;     ACET-WMFIN                --> ACETUTIL.FAS   Brings in WMF file
(defun txtexp (ss / grplst getgname blknm GLST GDICT  VIEW UPLFT TMPFIL TBX
                   TMPFIL CNT PT1 PT2 ENT TXT TXTYP PTLST ZM LOCKED GNAM)
  (acet-error-init
        (list
         (list   "cmdecho" 0
                 "highlight" 1
                 "osmode" 0
                 "Mirrtext" 1
                 "limcheck" 0
         T
; --------------------- GROUP LIST FUNCTION ----------------------
;   This function will return a list of all the group names in the
;   drawing and their entity names in the form:
;   ((<ename1> . <name1>) ... (<enamex> . <namex>))
  (defun acet-txtexp-grplst (/ GRP ITM NAM ENT GLST)
    (setq GRP  (dictsearch (namedobjdict) "ACAD_GROUP"))
    (while (setq ITM (car GRP))       ; While edata item is available
      (if (= (car ITM) 3)             ; if the item is a group name
        (setq NAM (cdr ITM)           ; get the name
              GRP (cdr GRP)           ; shorten the edata
              ITM (car GRP)           ; get the next item
              ENT (cdr ITM)           ; which is the ename
              GLST                    ; store the ename and name
                  (if GLST
                    (append GLST (list (cons ENT NAM)))
        (setq GRP (cdr GRP))          ; else shorten the edata
    GLST                              ; return the list
; ------------------- GET GROUP NAME FUNCTION --------------------
;   This function returns a list of all the group names in GLST
;   where ENT is a member. The list has the same form as GLST
  (defun acet-txtexp-getgname (ENT GLST / GRP GDATA NAM NLST)
    (if (and GLST (listp GLST))
        (foreach GRP GLST
          (setq GDATA (entget (car GRP)))
          (foreach ITM GDATA                   ; step through the edata
            (if (and
                  (= (car ITM) 340)            ; if the item is a entity name
                  (eq (setq NAM (cdr ITM)) ENT) ; and the ename being looked for
              (setq NLST                       ; store the ename and name
                      (if NLST
                        (append NLST (list (cons (car GRP) (cdr GRP))))
    NLST
;                          MAIN PROGRAM
  (if (and                                                ; Are we in plan view?
        (equal (car (getvar "viewdir")) 0 0.00001)
        (equal (cadr (getvar "viewdir")) 0 0.00001)
        (> (caddr (getvar "viewdir")) 0)
      (Setq GLST     (acet-txtexp-grplst)                             ; Get all the groups in drawing
            GDICT    (if GLST
            CNT      0
      ;; filter out the locked layers
      (if SS
        (setq SS (car (bns_ss_mod SS 1 T)))
      ) ;if
      ;; if we have anything left
      (if SS
          (setq CNT 0)                                 ; Reset counter
          (while (setq ENT (ssname SS CNT))            ; step through each object in set
            (and
              GLST                                     ; if groups are present in the drawing
              (setq GNAM (acet-txtexp-getgname ENT GLST))          ; and the text item is in one or more
              (foreach GRP GNAM                        ; step through those groups
                (command "_.-group" "_r"               ; and remove the text item
                  (cdr GRP) ENT ""
            (setq TBX (acet-geom-textbox (entget ENT) 0))   ; get textbox points
            (setq TBX (mapcar '(lambda (x)
                                 (trans x 1 0)         ; convert the points to WCS
                        TBX
            (setq PTLST (append PTLST TBX))            ; Build list of bounding box
                                                       ; points for text items selected
            (setq CNT (1+ CNT))                        ; get the next text item
          ); while
          (setq PTLST (mapcar '(lambda (x)
                                 (trans x 0 1)         ; convert all the points
                               )                       ; to the current ucs
                      PTLST
          (if (setq ZM (acet-geom-zoom-for-select PTLST))          ; If current view does not contain
            (progn                                     ; all bounding box points
              (setq ZM
                (list
                  (list (- (caar ZM) (acet-geom-pixel-unit))     ; increase zoom area by
                        (- (cadar ZM) (acet-geom-pixel-unit))    ; one pixel width to
                        (caddar ZM)                    ; sure nothing will be lost
                  (list (+ (caadr ZM) (acet-geom-pixel-unit))
                        (+ (cadadr ZM) (acet-geom-pixel-unit))
                        (caddr (cadr zm))
              (command "_.zoom" "_w" (car ZM) (cadr ZM))  ; zoom to include text objects
          (setq VIEW     (acet-geom-view-points)
                TMPFIL   (strcat (getvar "tempprefix") "txtexp.wmf")
                PT1      (acet-geom-midpoint (car view) (cadr view))
                PT2      (list (car PT1) (cadadr VIEW))
          (if (acet-layer-locked (getvar "clayer"))       ; if current layer is locked
              (command "_.layer" "_unl" (getvar "clayer") "")  ; unlock it
              (setq LOCKED T)
          (command "_.mirror" SS "" PT1 PT2 "_y"
                   "_.WMFOUT" TMPFIL SS "")
          (if (findfile tmpfil)                           ; Does WMF file exist?
              (command "_.ERASE" SS "")                   ; erase the orignal text
              (setq ss (acet-wmfin TMPFIL))               ; insert the WMF file
              (command "_.mirror" ss "" PT1 PT2 "_y")
            ) ;progn
          ) ;if
          (if LOCKED
            (command "_.layer" "_lock" (getvar "clayer") "") ; relock if needed
          ) ;if
          (if ZM (command "_.zoom" "_p"))              ; Restore original view if needed
          (prompt (acet-str-format "\n%1 text object(s) have been exploded to lines."  CNT))
          (prompt "\nThe line objects have been placed on layer 0.")
    (prompt "\nView needs to be in plan (0 0 1).")
  );if equal
  (acet-error-restore)                                  ; Retsore values
) ;end txtexp
(setq HOLDECHO (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(if (not ACET-ERROR-INIT)
  (load "acetutil")
(setq HOLDTEXTSTYLE (getvar "TEXTSTYLE"))
(command "style" "标楷体" "标楷体" "0" "1" "0" "n" "n")
;;;设TTF字型
;;;注意:字型直线多的如"细明体系列"容易出错
;;;我是用繁体字,简体字效果?????????未知!!!!!!!
(setvar "TEXTSTYLE" HOLDTEXTSTYLE)
(setvar "CMDECHO" HOLDECHO)
(setq holdecho nil
      holdtextstyle nil)
(defun C:3D_TEXT (/ N A SS LLL LL SSL)
  (setq        SS (ssget '((-4 . "<AND")
                    (-4 . "<OR")
                    (0 . "MTEXT")
                    (0 . "TEXT")
                    (-4 . "OR>")
                    (-4 . "<NOT")
                    (102 . "{ACAD_REACTORS")
                    (-4 . "NOT>")
                    (-4 . "AND>")
  (command "_.VIEW" "S" "3D_TEXT")
  (command "_.VIEW" "TOP")
  (setq SSL (sslength SS))
  (setq N 0)
  (repeat SSL
    (setq A (entget (ssname SS N)))
    (setq A (subst (cons 7 "标楷体") (assoc 7 A) A))
    (entmod A)
    (setq N (1+ N))
  (TXTEXP SS)
  (command "_.VIEW" "R" "3D_TEXT")
  (command "_.VIEW" "D" "3D_TEXT")
  (setq LL (entlast))
  (command "_.region" (ssget "p") "")
  (setq SS NIL)
  (setq SS (ssadd))
  (setq LLL (entnext LL))
  (ssadd LLL SS)
  (ssadd (entlast) SS)
  (while (not (eq LLL (entlast)))
    (ssadd LLL SS)
    (setq LLL (entnext LLL))
  (command "_.union" SS "")
  (command "_.extrude" SS "")
(prompt "\ntype 3d_text")
发表于 2002-3-1 16:52:00 | 显示全部楼层
我曾e_mail: 3DTEXT2.LSP原作者问是否有更新版for AUTO2000
回复如下:
No, I'm sorry, perhaps in future, i've so far been using only R14,
but i've received some questions from people using A2000 that it is
not working properly in the latest version ...
 楼主| 发表于 2002-3-2 19:25:00 | 显示全部楼层
斑竹,真是太感激了!呜呜呜呜……
发表于 2002-3-19 15:27:00 | 显示全部楼层
可以!
可以使用3dsmax制作,让后导出到cad
发表于 2002-5-19 12:34:00 | 显示全部楼层
用dxb文件最好
发表于 2002-5-19 12:39:00 | 显示全部楼层
我更喜欢用dxb
发表于 2002-6-18 07:52:00 | 显示全部楼层
GMT+8, 2025-5-7 17:13 , Processed in 0.174767 second(s), 24 queries , Gzip On.
