查看: 1673|回复: 5
求优化。画焊缝的程序,图形大时执行很慢。谢谢
发表于 2015-5-21 15:06:50 | 显示全部楼层 |阅读模式
1明经币
(defun err (s)
        (if (/= s "Function cancelled")
                (princ (strcat "\nError: " s))
        (setq sset nil)
        (setq *error* olderr)
(defun c:hf()
  (setvar "cmdecho" 0)
  (setq oldoffsetdist (getvar "offsetdist"))
  (setq oldosmode (getvar "osmode"))
  (setvar "dimzin" 0)
  (setq olderr *error*
               *error* err)
  (command "undo" "group")
  (setq pt1 (getpoint"\n请选择要添加焊缝上的直线上的焊缝起点:"))
  (setq pt2 (getpoint"\n请选择要添加焊缝上的直线上的焊缝终点:"))
  (setq pt3 (getpoint"\n请选择要添加焊缝的一侧:"))
  (setvar "osmode" 0)
  (setq hfjl (distance pt1 pt2))
  (command "line" pt1  pt2 "")
  (setq en1 (entlast))
  (command "offset" "0.466666666666667" en1 pt3 "")
  (setq en2 (entlast))
  (setq en11 (entget en1))
  (setq en22 (entget en2))
  (setq qd11 (cdr (assoc 10 en11)))
  (setq qd22 (cdr (assoc 10 en22)))
  (command "line" qd11 qd22 "")
  (setq en3 (entlast))
  (command "offset" "0.4" en3 pt2 "")
  (setq en4 (entlast))
  (setq n (/ hfjl 0.533333333333333333))
  (setq n (fix n))
  (setq m 1)
  (while (>= n m)
    (setq jl1 (* m 0.5333333333333))
    (command "offset" jl1 en4 pt2 "")
    (setq m (+ 1 m))
  (command "erase" en1 en2 en3 "")
  (command "undo" "end")
  (setvar "osmode" oldosmode)
  (setvar "offsetdist" oldoffsetdist)
  (setvar "cmdecho" 1)
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2015-5-21 15:06:51 | 显示全部楼层
  1. (vl-load-com)
  2. (defun c:pp (/ en1 pt pt1 pt2 Deriv ang ang1 ang2 l n i)
  3.   (setvar "cmdecho" 0)
  4.   (command "undo" "group")
  5.   (setq        en1   (entsel "\n选择焊件:")
  6.         pt    (cadr en1)
  7.         en1   (car en1)
  8.         pt1   (vlax-curve-getClosestPointTo en1 pt)
  9.         Deriv (vlax-curve-getSecondDeriv
  10.                 en1
  11.                 (vlax-curve-getParamAtPoint en1 pt1)
  12.               )
  13.         ang1  (angle pt1 pt)
  14.         ang2  (angle pt1 (mapcar '+ pt1 Deriv))
  15.         l     (vlax-curve-getdistatPoint en1 (vlax-curve-getendPoint en1))
  16.         n     (fix(/ (- l 0.4) 0.533333))
  17.         i     0
  18.   )
  19.   (repeat (1+ n)
  20.     (setq pt (vlax-curve-getPointAtDist en1 (+ 0.4 (* 0.53333 i)))
  21.           i  (1+ i)
  22.     )
  23.     (if        (equal Deriv '(0. 0. 0.) 1e-6)
  24.       (entmake (list '(0 . "line")
  25.                      (cons 10 pt)
  26.                      (cons 11 (polar pt ang1 0.46666666666))
  27.                )
  28.       )
  29.       (if (equal ang1 ang2 1e-6)
  30.         (entmake
  31.           (list
  32.             '(0 . "line")
  33.             (cons 10 pt)
  34.             (cons
  35.               11
  36.               (polar pt
  37.                      (angle pt
  38.                             (mapcar '+
  39.                                     pt
  40.                                     (vlax-curve-getSecondDeriv
  41.                                       en1
  42.                                       (vlax-curve-getParamAtPoint en1 pt)
  43.                                     )
  44.                             )
  45.                      )
  46.                      0.46666666666
  47.               )
  48.             )
  49.           )
  50.         )
  51.         (entmake
  52.           (list
  53.             '(0 . "line")
  54.             (cons 10 pt)
  55.             (cons
  56.               11
  57.               (polar
  58.                 pt
  59.                 (+ pi
  60.                    (angle pt
  61.                           (mapcar '+
  62.                                   pt
  63.                                   (vlax-curve-getSecondDeriv
  64.                                     en1
  65.                                     (vlax-curve-getParamAtPoint en1 pt)
  66.                                   )
  67.                           )
  68.                    )
  69.                 )
  70.                 0.46666666666
  71.               )
  72.             )
  73.           )
  74.         )
  75.       )
  76.     )
  77.   )
  78.   (command "undo" "end")
  79.   (princ)
  80. )
发表于 2015-5-22 16:45:53 | 显示全部楼层
不知道是否需要考虑起弧落弧
发表于 2015-5-23 10:08:08 | 显示全部楼层
什么专业画焊缝这么画啊?随便写的,比较随意,选择框中心在线的哪一边就画在哪一边,可用于直线与圆弧,代码见楼下
 楼主| 发表于 2015-5-23 17:41:33 | 显示全部楼层
好的,谢谢。如调整线的长度和间距需调哪些数据。谢谢
发表于 2015-5-24 08:59:19 | 显示全部楼层
里面的0.4,0,466,0.533
GMT+8, 2025-5-1 12:44 , Processed in 0.191455 second(s), 26 queries , Gzip On.
