查看: 897|回复: 2
删除对象出错
发表于 2015-5-7 16:09:31 | 显示全部楼层 |阅读模式
我想删除这个对象,但是一运行   obj.Erase(True)   cad就崩掉,要怎么操作才能删除它啊,求解,谢谢!
Public Sub GetXData()
        Dim doc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim peo As PromptEntityOptions = New PromptEntityOptions("\n请选择实体:")
        Dim per As PromptEntityResult = ed.GetEntity(peo)
        'Dim ent As Entity = Nothing
        If per.Status = PromptStatus.OK Then
            Dim trans As Transaction = doc.TransactionManager.StartTransaction()
            Dim obj As Entity = trans.GetObject(per.ObjectId, OpenMode.ForRead)
            Dim rb As ResultBuffer = obj.XData
            If rb Is Nothing Then
                ed.WriteMessage("\n实体不包括扩展数据")
            Else
                Dim n As Integer = 0
                Dim tv As TypedValue
                For Each tv In rb
                    ed.WriteMessage("\n类型值{0} - 类型: {1}, 值: {2}", n, tv.TypeCode, tv.Value)
                    n = n + 1
                Next
                Try
                    If Not obj = Nothing Then
                        obj.Erase(True)
                    End If
                Catch ex As Exception
                    MsgBox(ex.Message)
                End Try
                rb.Dispose()
            End If
            trans.Dispose()
        End If
    End Sub
发表于 2015-5-7 17:40:38 来自手机 | 显示全部楼层
实体删除要写打开
 楼主| 发表于 2015-5-8 09:23:10 | 显示全部楼层
果然如此啊,是我粗心了。谢谢!
GMT+8, 2025-5-1 22:59 , Processed in 0.171500 second(s), 23 queries , Gzip On.
