查看: 1306|回复: 5
代码加载后多次运行会导致CAD崩溃,百思不得其解
发表于 2015-5-3 19:43:55 | 显示全部楼层 |阅读模式
运行一次还好,第二次CAD就崩溃,自动关闭或APPLICATION 停止工作。百思不得其解,请各位老师指教!详细见代码及实验用图
由于自己找不到原因,所以说不出所以然,大概确定问题应该在第二个
using (Transaction trans = doc.TransactionManager.StartTransaction())的部分里(文字lable点化之后)
奇怪的是,有时去掉获取质心或获取自身地块编码的代码部分,就能多运行几次才崩溃,到底是什么原因呢?
代码:
public void SZSM()
      Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
      Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
      Database db = HostApplicationServices.WorkingDatabase;
      #region 整体文字lable点化
      try
        TypedValue[] TXT_typevalues = new TypedValue[]
       new TypedValue((int) DxfCode.LayerName, "地块编码,权利人,地类编码,四至" ),
       new TypedValue ((int) DxfCode.Start, "TEXT")
        SelectionFilter TXT_filter = new SelectionFilter(TXT_typevalues);
        PromptSelectionResult TXT_psr = ed.SelectAll(TXT_filter);
        SelectionSet TXT_ss = TXT_psr.Value;
          foreach (ObjectId TXT_id in TXT_ss.GetObjectIds())
            Entity ent = (Entity)trans.GetObject(TXT_id, OpenMode.ForWrite);
            DBText mark = (DBText)ent; mark.Height = 0.000000000001;
          TXT_ss = null; ed.WriteMessage("处理相关文字...");
          trans.Commit();
      catch (SystemException ex)
      { MessageBox.Show("处理相关文字失败:\r\n"+ex.Message, "错误", MessageBoxButtons.OK, MessageBoxIcon.Error); }
      #endregion
      #region 选择集过滤:承包地块
      TypedValue[] CBDK_typevalues = new TypedValue[]
       new TypedValue((int) DxfCode.LayerName, "承包地块" ),
       new TypedValue ((int) DxfCode.Start, "LWPOLYLINE")
      SelectionFilter CBDK_filter = new SelectionFilter(CBDK_typevalues);
      PromptSelectionResult CBDK_psr = ed.SelectAll(CBDK_filter);
      SelectionSet CBDK_ss = CBDK_psr.Value;
      #endregion
        BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead); //以读方式打开块表.
        BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
        foreach (ObjectId CBDK_id in CBDK_ss.GetObjectIds())//遍历每个承包地块
          string SelfDKBM = "###";//自身地块编码
          Polyline CBDK_PL = trans.GetObject(CBDK_id, OpenMode.ForWrite) as Polyline;
          CBDK_PL.Elevation = 0; CBDK_PL.ColorIndex = 1;//自身承包地块变色
          #region 建立缓冲区外围线
          DBObjectCollection OffsetPLcc_FN = null; DBObjectCollection OffsetPLcc_FM = null;
          if (CBDK_PL.Clockwise())//判断绘制方向
          { OffsetPLcc_FN = CBDK_PL.GetOffsetCurves(-3); OffsetPLcc_FM = CBDK_PL.GetOffsetCurves(-10); }
          else { OffsetPLcc_FN = CBDK_PL.GetOffsetCurves(3); OffsetPLcc_FM = CBDK_PL.GetOffsetCurves(10); }
          #endregion
          #region 取得自身地块编码号
          Point3dCollection SelfShapePoint = new Point3dCollection();
          for (int i = 0; i < CBDK_PL.NumberOfVertices; i++)
            SelfShapePoint.Add(CBDK_PL.GetPoint3dAt(i));
          TypedValue[] SelfDKBM_values = new TypedValue[]
            new TypedValue((int)DxfCode.LayerName, "地块编码"),
            new TypedValue((int)DxfCode.Start, "TEXT")
          SelectionFilter SelfDKBM_filter = new SelectionFilter(SelfDKBM_values);
          PromptSelectionResult SelfDKBM_psr = ed.SelectCrossingPolygon(SelfShapePoint, SelfDKBM_filter);
          SelectionSet SelfDKBM_ss = SelfDKBM_psr.Value;
          if (SelfDKBM_ss.Count == 1)
            ObjectId[] SelfDKBM_Obj = SelfDKBM_ss.GetObjectIds();
            if (SelfDKBM_Obj[0] != null)
              Entity SelfDKBM_ent = trans.GetObject(SelfDKBM_Obj[0], OpenMode.ForWrite) as Entity;
              if (SelfDKBM_ent != null)
                DBText DKBM = (DBText)SelfDKBM_ent;
                SelfDKBM = DKBM.TextString.ToString();
          else { SelfDKBM = "不确定地块编码"; }
          #endregion
          #region 扫描过程
          for (int i = 0; i < OffsetPLcc_FN.Count; i++)
            Polyline OffsetPL_FN = (Polyline)OffsetPLcc_FN;
            OffsetPL_FN.Elevation = 0; OffsetPL_FN.Layer = "0";
            btr.AppendEntity(OffsetPL_FN);
            trans.AddNewlyCreatedDBObject(OffsetPL_FN, true);
            //btr.AppendEntity((Entity)OffsetPLcc_FM);
            //trans.AddNewlyCreatedDBObject((Entity)OffsetPLcc_FM, true);
          #endregion
        trans.Commit();
    }//SZSM
发表于 2015-5-3 21:23:05 来自手机 | 显示全部楼层
selectall也可能为null
 楼主| 发表于 2015-5-3 21:45:40 | 显示全部楼层
ivde 发表于 2015-5-3 21:23
selectall也可能为null
兄弟是说,之后的运行中,SelectAll可能返回null?但是不应该啊,图形都是ZoomE的
发表于 2015-5-3 23:11:38 来自手机 | 显示全部楼层
选择后修改了,再选择就不一定有选集
发表于 2015-5-4 06:48:04 来自手机 | 显示全部楼层
用com反射获取质心试试
另外 我一般把选择集写在事务的外面
选择集的返回状态最好也要做判断
发表于 2015-5-4 07:40:08 | 显示全部楼层
Polyline绘图不规范的时候不一定能生成 Region,可能为 null
避免崩溃方法就是用 try ... catch 结构,否则就多增加 if 判断
try
     myRegionColl = Region.CreateFromCurves(acDBObjColl);
     Region acRegion = myRegionColl[0] as Region;
cathc {}
or
if (myRegionColl.count != 0 && myRegionColl[0] != Region.IsNull)
GMT+8, 2025-5-2 01:26 , Processed in 0.232264 second(s), 24 queries , Gzip On.
