查看: 1625|回复: 0
AcDbXrecord 和vlax-ldata-put有什么关系啊?
发表于 2015-4-16 17:30:46 | 显示全部楼层 |阅读模式
为什么我用Lisp(vlax-ldata-put "Userdict" "BYSCALE" 1)
用arx读,返回pRb为Null呢?
double GetNameDictDouble(ACHAR* dict,ACHAR* key)        //(vlax-ldata-get "Userdict" "BYSCALE")
        ZffCHAP5AddNameDict();
        ZffCHAP5ViewNameDict();
        Acad::ErrorStatus es;
        struct resbuf *pRb;
        AcDbObjectId xrecObjId;
        double ret;
        // 获得有名对象字典,向其中添加指定的字典项
        AcDbDictionary *pNameObjDict, *pDict;
        acdbHostApplicationServices()->workingDatabase()->getNamedObjectsDictionary(pNameObjDict,AcDb::kForWrite);
        // 检查所要添加的字典项是否已经存在
        AcDbObjectId dictObjId;
        es=pNameObjDict->getAt(dict, (AcDbObject*&)pDict,AcDb::kForWrite);
        if ( es== Acad::eKeyNotFound)
                pDict = new AcDbDictionary;
                pNameObjDict->setAt(dict, pDict, dictObjId);
                pDict->close();
                pNameObjDict->close();
                // 向新建的字典中添加一个扩展记录
                AcDbXrecord *pXrec = new AcDbXrecord;
                acdbOpenObject(pDict, dictObjId, AcDb::kForWrite);
                pDict->setAt(key, pXrec, xrecObjId);
                pDict->close();
                pRb = acutBuildList(AcDb::kDxfReal, 1,        //把BYSCALE设为1
                        0);
                pXrec->setFromRbChain(*pRb);
                pXrec->close();
                acutRelRb(pRb);
                return 1;
                //pRb->resval.rreal
        // 获得指定的对象字典
        AcDbXrecord *pXrec;
        es=pDict->getAt(key, (AcDbObject*&)pXrec, AcDb::kForWrite);
                //pDict->close();
                //es=pDict->getAt(key, (AcDbObject*&)pXrec, AcDb::kForWrite);
                pDict->close();
                        0);
                pXrec->close();
                acutRelRb(pRb);
        pDict->close();
        // 获得扩展记录的数据链表并关闭扩展数据对象
        es=pXrec->rbChain(&pRb);
        pXrec->close();
        if (pRb != NULL)
                ret= pRb->resval.rreal;
                acutRelRb(pRb);
                return ret;
        else
                return 1;
同样,我在arx中设置的MyDict,XRecord在Lisp里同样读不出来
void ZffCHAP5AddNameDict()
        // 要在扩展记录中保存的字符串
        char entType[] = {"直线"};
        struct resbuf *pRb;
                AcDb::kForWrite);
        // 检查所要添加的字典项是否已经存在
        if (pNameObjDict->getAt(L"MyDict", (AcDbObject*&)pDict,
                AcDb::kForWrite) == Acad::eKeyNotFound)
                pNameObjDict->setAt(L"MyDict", pDict, dictObjId);
                pDict->close();
        // 向新建的字典中添加一个扩展记录
        pDict->setAt(L"XRecord", pXrec, xrecObjId);
        pDict->close();
        // 设置扩展记录的内容
        ads_point pt;
        pt[X] = 100;
        pt[Y] = 100;
        pt[Z] = 0;
        pRb = acutBuildList(AcDb::kDxfText, entType,
                AcDb::kDxfInt32, 12,
                AcDb::kDxfReal, 3.14,
                AcDb::kDxfXCoord, pt,
                RTNONE);
        pXrec->close();
        acutRelRb(pRb);
GMT+8, 2025-5-1 09:37 , Processed in 0.153660 second(s), 23 queries , Gzip On.
