查看: 1554|回复: 9
[基础] 先谢谢大家,开发插件遇到的几个小问题,希望大神帮忙解决,谢谢!
发表于 2015-4-14 22:21:45 | 显示全部楼层 |阅读模式
1.加载了自己的程序,出现界面,打开DWG文件,随意点击DWG里的块参照。但是,怎么才能让插件和点击块参照有联系。。可能我解释的不清楚,上个图希望大家帮忙。 就是希望实现 选取了块参照 就show出面板上的panel
2.这段代码希望大家帮忙看看,我实在是解决不了了。就是希望添加块,添加信息,然后这些信息可以增删改。我用的datatable存储信息,不知道可不可以实现。。另外此代码只能运行成功一下,第二次就有对象错误问题(也就不能连续添加块记录),实在不会解决.代码如下,谢谢大家!万分感谢!
      [CommandMethod("atat")]  //输入此命令可运行
        public void atat()
            Writedata("男","25");
        [CommandMethod("AddAttributeBlock")]
        public void AddAttributeBlock(String cbf,string dkbh)
            Database db = HostApplicationServices.WorkingDatabase;
            ObjectId id;
            BlockTableRecord btr = new BlockTableRecord();
               Point3d pt = Pick1("\n指定位置");
               //String cbf = GetString("\n承包方");
               //String dkbh = GetString("地块编号");
            Line li = new Line(pt,new Point3d(0,0,0));//new Point3d(30, 30, 0)
           // Line li = new Line();
           // PromptEntityResult ent;
          //  DBText txt = DBText(pt, str, 5);
            AttributeDefinition ad1 = AttributeDefinition("Length", "L", cbf, new Point3d(pt.X + 3, pt.Y + 3, 0));
            AttributeDefinition ad2 = AttributeDefinition("Length", "L", dkbh, new Point3d(pt.X - 3, pt.Y - 3, 0));
            btr.Name = "LineBlock";
            btr.AppendEntity(li);
            btr.AppendEntity(ad1);
            btr.AppendEntity(ad2);
           // Writedata(str1,str2);
            id =AddToBlockTable(btr);
            ToModelSpace(id, pt, db);
        //创建属性
        public static AttributeDefinition AttributeDefinition(string label, string prompt, string value, Point3d pt)
            AttributeDefinition ad = new AttributeDefinition();
            ad.Constant = false;
            ad.Tag = label;
            ad.Prompt = prompt;
            ad.TextString = value;
            ad.Position = pt;
            return ad;
        //将指定的块定义变成块参照添加到指定的模型空间
        public static ObjectId ToModelSpace(ObjectId blkid, Point3d pt, Database db)
            ObjectId blkrfid = new ObjectId();
            using (Transaction trans = db.TransactionManager.StartTransaction())
                BlockTable bt = trans.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                BlockTableRecord modelspace = trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                BlockTableRecord block = trans.GetObject(blkid, OpenMode.ForRead) as BlockTableRecord;
                BlockReference br = new BlockReference(pt, blkid);//通过块定义 添加块参照
                blkrfid = modelspace.AppendEntity(br);//把块参照添加到块表记录
                trans.AddNewlyCreatedDBObject(br, true);
                foreach (ObjectId id in block)
                if (id.ObjectClass.Equals(RXClass.GetClass(typeof(AttributeDefinition))))
                  AttributeDefinition ad = trans.GetObject(id, OpenMode.ForRead) as AttributeDefinition;
                 AttributeReference ar = new AttributeReference(ad.Position, ad.TextString, ad.Tag, new ObjectId());
                 br.AttributeCollection.AppendAttribute(ar);
                trans.Commit();
            return blkrfid;
        //将块表记录加入到块表中
        public static ObjectId AddToBlockTable(BlockTableRecord Record)
            ObjectId id = new ObjectId();
            using (Transaction transaction = db.TransactionManager.StartTransaction())
                BlockTable table = transaction.GetObject(db.BlockTableId, OpenMode.ForWrite) as BlockTable;
                //BlockTableRecord btr = transaction.GetObject(table.);
                if (table.Has("LineBlock"))
                   id = table["LineBlock"];
                   return id;
                  /* BlockTableRecord btr = new BlockTableRecord();//这几行可以继续添加块参照,但是快参照是空白。什么都没有
                   btr.Name = "aaa";
                   id = table.Add(btr);
                    transaction.AddNewlyCreatedDBObject(btr,true);
                    transaction.Commit();
                    return id;*/
                id = table.Add(Record);
                transaction.AddNewlyCreatedDBObject(Record, true);
            return id;
        [CommandMethod("WriteData")]//写入数据
        public void Writedata(String fbfbmstr, String cbfbmstr)
            Autodesk.AutoCAD.DatabaseServices.DataTable dt = new Autodesk.AutoCAD.DatabaseServices.DataTable();
            dt.TableName = "ParameterTable";
            dt.AppendColumn(CellType.CharPtr, "姓名");
            dt.AppendColumn(CellType.CharPtr, "地址");
            dt.AppendColumn(CellType.CharPtr, "性别");
            dt.AppendColumn(CellType.CharPtr, "年龄");
            DataCellCollection Row = new DataCellCollection();
            DataCell cbf = new DataCell();
            DataCell dkbh = new DataCell();
            DataCell fbfbm = new DataCell();
            DataCell cbfbm = new DataCell();
            string xm = GetString("\n姓名");
            string dz = GetString("\n地址");
            AddAttributeBlock(xm, dz);
            cbf.SetString(xm);
            dkbh.SetString(dz);
            fbfbm.SetString(fbfbmstr);
            cbfbm.SetString(cbfbmstr);
          //  Parameter.SetString(GetString("\n输入尺寸"));
            Row.Add(cbf);
            Row.Add(dkbh);
            Row.Add(fbfbm);
            Row.Add(cbfbm);
           // Row.Add(Parameter);
            dt.AppendRow(Row, true);
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptEntityResult ent = ed.GetEntity("\n选择要写数据的对象");
            if (ent.Status == PromptStatus.OK)
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    Entity entity = tr.GetObject(ent.ObjectId, OpenMode.ForWrite, true) as Entity;
                    if (entity.ExtensionDictionary == new ObjectId())
                        entity.CreateExtensionDictionary();
                    DBDictionary extensionDic = tr.GetObject(entity.ExtensionDictionary, OpenMode.ForWrite, false) as DBDictionary;
                    extensionDic.SetAt("ParameterTable", dt);
                    tr.AddNewlyCreatedDBObject(dt, true);
                    tr.Commit();
        [CommandMethod("ReadData")]  //读取数据
        public void ReadData()
            Entity entity = null;
            PromptEntityResult ent = ed.GetEntity("\n选择要读取数据的对象");
                    entity = transaction.GetObject(ent.ObjectId, OpenMode.ForRead, true) as Entity;
                    DBDictionary extensionDic = transaction.GetObject(entity.ExtensionDictionary, OpenMode.ForRead) as DBDictionary;
                    Autodesk.AutoCAD.DatabaseServices.DataTable dt = transaction.GetObject(extensionDic.GetAt("ParameterTable"), OpenMode.ForWrite) as Autodesk.AutoCAD.DatabaseServices.DataTable;
                    ed.WriteMessage("\n Name:" + dt.GetCellAt(0, 0).Value.ToString());
                    ed.WriteMessage("\n Meterial:" + dt.GetCellAt(0, 1).Value.ToString());
                    ed.WriteMessage("\n Parameter:" + dt.GetCellAt(0, 2).Value.ToString());
                    Autodesk.AutoCAD.DatabaseServices.DataColumn nameColumn = dt.GetColumnAt(0);
                    Autodesk.AutoCAD.DatabaseServices.DataColumn meterialColumn = dt.GetColumnAt(1);
                    Autodesk.AutoCAD.DatabaseServices.DataColumn parameterColumn = dt.GetColumnAt(2);
                    ed.WriteMessage("\n Meterial:" + meterialColumn.GetCellAt(0).ToString());
                    ed.WriteMessage("\n Meterial:" + parameterColumn.GetCellAt(0).Value.ToString());
 楼主| 发表于 2015-4-14 22:24:11 | 显示全部楼层
在线等,希望大家可以帮帮忙,小弟能力有限,只能麻烦大家了~ 环境CAD2010+VS2008
发表于 2015-4-14 23:13:45 来自手机 | 显示全部楼层
数据放在字典没错
但一般都是存储成一条记录
像你这样放在datatable....应该是前所未闻的
发表于 2015-4-14 23:15:25 来自手机 | 显示全部楼层
如果数据比较简单 用扩展数据xdata也行
 楼主| 发表于 2015-4-14 23:52:20 | 显示全部楼层
谢谢!!我看的书是深入浅出.net cad二次开发。 xdata只有三行文字的介绍,实在无力。可以先帮忙解决第一个问题吗?Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            PromptSelectionResult i = ed.SelectPrevious();
            if (i.Status == PromptStatus.OK)
                         this.panel1.Location = new Point(0,0);
            this.panel1.Visible = true;
            else
            this.panel1.Location = new Point(-10000,-10000);
我在帖子里搜索到说用SelectPrevious,写了这个 ,不过运行之后没有显示出panel,另外 扩展数据xdata 是不是 -3  ??
 楼主| 发表于 2015-4-14 23:54:32 | 显示全部楼层
雪山飞狐_lzh 发表于 2015-4-14 23:13
数据放在字典没错
但一般都是存储成一条记录
飞狐哥,我该怎么做呢?可以给个思路吗 我只是把那本“深入浅出”代码以及实例做了一遍,具体该怎么联系起来,没有一点思路 可以教教我吗? 其实要输入的数据全在块参照里,修改也在块参照,显示也是通过块参照,可以教我怎么做吗?谢谢!
发表于 2015-4-15 08:12:53 | 显示全部楼层
建议你先把基础的东西搞清楚 而不是直接Copy代码
置顶帖的指南翻译版 你可以看看 里面的代码很多
 楼主| 发表于 2015-4-15 09:05:57 | 显示全部楼层
好的,谢谢啊
 楼主| 发表于 2015-4-19 01:19:19 | 显示全部楼层
谢谢飞狐哥,问题已经解决。不过第一个问题解决了一半,操作显得麻烦不通畅,暂时研究其他重要点的功能,谢谢你·
发表于 2015-4-19 22:02:46 来自手机 | 显示全部楼层
和界面关联据说用绑定是正解
GMT+8, 2025-5-1 23:35 , Processed in 0.174572 second(s), 23 queries , Gzip On.
