查看: 1603|回复: 2
[基础] 关于Teigha表格应用
发表于 2015-3-24 10:08:55 | 显示全部楼层 |阅读模式
大家好,我看了看帖子,好像有关于Teigha的介绍,现在是这个情况,写了几段代码测试,发现画其他诸如线条、文字之类的都可以,但是制作表格的时候出错,具体是在database.SaveAs时候报的:Teigha.Runtime.Exception: Null object Id
代码如下:  大侠们帮我看看呢,不知道哪里的问题
using (Services svcs = new Services())
                Database db = new Database();
                using (Transaction trans = db.TransactionManager.StartTransaction())
                    BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
                    BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                    Teigha.DatabaseServices.Table tb = new Teigha.DatabaseServices.Table();
                    double fontWeight = 5;
                    double rowHeight = 10;
                    tb.NumRows = 3;
                    tb.NumColumns = 6;
                    tb.Position = new Point3d(0, 0, 0);
                    tb.SetAlignment(1, 5, CellAlignment.MiddleCenter);
                    tb.SetTextString(1, 5, "备注1");
                    tb.SetAlignment(2, 1, CellAlignment.MiddleCenter);
                    tb.SetTextString(2, 1, "备注2");
                    tb.SetAlignment(2, 2, CellAlignment.MiddleCenter);
                    tb.SetTextString(2, 2, "备注3");
                    tb.SetAlignment(2, 3, CellAlignment.MiddleCenter);
                    tb.SetTextString(2, 3, "备注4");
                    tb.SetAlignment(2, 4, CellAlignment.MiddleCenter);
                    tb.SetTextString(2, 4, "备注5");
                    ObjectId tbID = btr.AppendEntity(tb);
                    trans.AddNewlyCreatedDBObject(tb, true);
                    trans.Commit();
                db.SaveAs("D:\\test.dwg", DwgVersion.Current);//此行报错:Teigha.Runtime.Exception: Null object Id
发表于 2015-3-25 19:44:16 来自手机 | 显示全部楼层
应该是有属性没设置? 或者teigha的库不完善?
 楼主| 发表于 2015-3-26 10:58:47 | 显示全部楼层
搞不清楚唉,试过很多办法了
GMT+8, 2025-5-2 01:10 , Processed in 0.191863 second(s), 23 queries , Gzip On.
