查看: 1343|回复: 0
[基础] 请教使用scripting.filesystemobject的问题
发表于 2015-3-14 00:39:20 | 显示全部楼层 |阅读模式
文件夹下只有D:\cg\2.dwg,D:\cg\3.dwg,D:\cg\Drawing1.dwg这三个文档
代码:
Set scr_obj = CreateObject("scripting.filesystemobject")
Set folder_obj = scr_obj.GetFolder(Text2.Text)
Set files_obj = folder_obj.Files
num=0
For Each file In files_obj
If Right(file.Name, 3) = "dwg" Then '是否为dwg
Debug.Print file.Path
num=num+1
end if
next
发现有时循环了三个文件,有时重复了一个文件,为什么呢?
运行结果:
D:\cg\2.dwg
D:\cg\3.dwg
D:\cg\Drawing1.dwg
D:\cg\3.dwg
D:\cg\Drawing1.dwg
D:\cg\2.dwg
D:\cg\3.dwg
GMT+8, 2025-5-2 01:26 , Processed in 0.210669 second(s), 27 queries , Gzip On.
