查看: 1425|回复: 2
VB怎样将整张图纸制成一个块
发表于 2015-2-24 16:21:09 | 显示全部楼层 |阅读模式
    Dim BlockRefobj As AcadBlockReference
    Dim Blockobject As AcadBlock
    Dim Blockinspoint(0 To 2) As Double
    Blockinspoint(0) = 0
    Blockinspoint(1) = 0
    Blockinspoint(2) = 0
    Set Blockobject = ThisDrawing.Blocks.Add(Blockinspoint, "block1") '这是添加对象  要怎样才可以一次性添加所有对象
发表于 2015-2-25 19:46:07 | 显示全部楼层
AttachExternalReference
然后
bind
发表于 2015-2-27 20:51:40 | 显示全部楼层
  1. 直接插入文件成块:
  2. Public Sub ss()
  3.     Dim p1
  4.             p1 = ThisDrawing.Utility.GetPoint(, "请指定插入点<0,0>:")
  5.     If IsEmpty(p1) Then
  6.         'ReDim P1(2)
  7.         p1 = Array(0, 0, 0)
  8.     End If
  9.     ThisDrawing.ModelSpace.InsertBlock p1, "D:\Program Files\shlisp2008\Blklib\卫生间详图\-1f集水坑.dwg", 1, 1, 1, 0
  10. End Sub
GMT+8, 2025-5-26 06:13 , Processed in 0.159208 second(s), 22 queries , Gzip On.
