查看: 1207|回复: 0
[JIG] 在进行块参照拖拽即时绘图时有时会出现如下错误?
发表于 2015-2-12 14:03:33 | 显示全部楼层 |阅读模式
错误行代码如下:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.GraphicsInterface;
namespace 标准化单机版
  public  class EntJip:DrawJig
      public Entity m_blo;
        //public BlockReference m_blo;
        private Point3d m_pt1, m_pt2;
        private double rotate;
        private double scale;
        public EntJip(Point3d pt1,  BlockReference blo,double sc)
            m_pt1 = pt1;//块的插入点
            m_blo = blo as Entity;
            rotate = 0;
            scale = sc;
        protected override bool WorldDraw(WorldDraw draw)
            draw.Geometry.Draw(m_blo);
             return false;
        protected override SamplerStatus Sampler(JigPrompts prompts)
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            Matrix3d mt = ed.CurrentUserCoordinateSystem;
            JigPromptPointOptions optJigPoint = new JigPromptPointOptions("\n请指定第二点:");
            optJigPoint.Cursor = CursorType.NoSpecialCursor;
            optJigPoint.UserInputControls = UserInputControls.Accept3dCoordinates
                | UserInputControls.NoZeroResponseAccepted
                | UserInputControls.NoNegativeResponseAccepted;
            optJigPoint.BasePoint = m_pt1.TransformBy(mt);//基点必须是WCS点
            optJigPoint.UseBasePoint = true;
            //获得点
            //try
                PromptPointResult resJigPoint = prompts.AcquirePoint(optJigPoint);//错误信息中说在这行出错
                m_pt2 = resJigPoint.Value;
                if (resJigPoint.Status != PromptStatus.OK) return SamplerStatus.Cancel;
                Point3d ucsPt = m_pt2.TransformBy(mt.Inverse());
                double temprotate = ucsPt.AngleFromXAxis(m_pt1);
                //拖拽取消
                if (resJigPoint.Status == PromptStatus.Cancel)
                //进行拖拽
                if (rotate != temprotate)
                    double rotateangle = temprotate - rotate;
                    rotate = temprotate;
                    m_blo.TransformBy(Matrix3d.Scaling(scale, m_pt1.TransformBy(mt)) * Matrix3d.Rotation(rotateangle, Vector3d.ZAxis, m_pt1.TransformBy(mt)));
                    return SamplerStatus.OK;
                else
                    return SamplerStatus.NoChange;
            //catch (Exception ex)
            //    Application.ShowAlertDialog(ex.Message);
            //    return SamplerStatus.NoChange;
还请高手抽时间给分析一下! 多谢
GMT+8, 2025-5-2 03:17 , Processed in 0.160748 second(s), 25 queries , Gzip On.
