查看: 2678|回复: 10
过滤器的选择的问题
发表于 2015-2-2 21:52:27 | 显示全部楼层 |阅读模式
按理来说我这个没错误,但一运行显示 参数 filter list(位于selectonscreen中)无效    麻烦帮忙看看啊
'设置过滤器
    Dim filtertype(0 To 3) As Integer
    Dim filterdate(0 To 3) As Variant
    filtertype(0) = -4
    filterdate(0) = " <or "
    filtertype(1) = 0
    filterdate(1) = "lwpolyline"
    filtertype(2) = 0
    filterdate(2) = "line"
    filtertype(3) = -4
    filterdate(3) = " or > "
    ThisDrawing.Utility.Prompt "选择要偏移的多段线:"
    SSet.SelectOnScreen filtertype, filterdate
发表于 2015-2-2 23:20:00 | 显示全部楼层
filtertype,filterdate必须是变体variant,而不是数组,你再定义两个变体,把这两个数组赋值给定义的两个变体即可
你这就是误导人家! 第一个数组绝对不需要是变体类型  发表于 2015-2-4 11:00
发表于 2015-2-2 23:47:10 来自手机 | 显示全部楼层
我现在有电脑测试了,发现楼主的问题就是在数组中多打了空格,按下面的就可以了
  1. Sub Test()
  2.     Dim sset As AcadSelectionSet
  3.     Dim filtertype(0 To 3) As Integer
  4.     Dim filterdate(0 To 3) As Variant
  5.
  6.     Set sset = ThisDrawing.SelectionSets.Add("test")
  7.     filtertype(0) = -4
  8.     filterdate(0) = "<or"
  9.     filtertype(1) = 0
  10.     filterdate(1) = "lwpolyline"
  11.     filtertype(2) = 0
  12.     filterdate(2) = "line"
  13.     filtertype(3) = -4
  14.     filterdate(3) = "or>"
  15.     ThisDrawing.Utility.Prompt "选择要偏移的多段线:"
  16.     sset.SelectOnScreen filtertype, filterdate
  17.
  18. End Sub
请先充实一下自己,再来说别人吧!  发表于 2015-2-3 10:53
发表于 2015-2-2 23:49:45 来自手机 | 显示全部楼层
某些人不服气,我就上个视频
呵呵,好吧,你赢了  发表于 2015-2-4 13:52
发表于 2015-2-3 10:54:27 | 显示全部楼层
  1. Public Sub ss()
  2. Dim filtertype(0 To 3) As Integer
  3.     Dim filterdate(0 To 3) As Variant
  4.     filtertype(0) = -4
  5.     filterdate(0) = "<or"
  6.     filtertype(1) = 0
  7.     filterdate(1) = "lwpolyline"
  8.     filtertype(2) = 0
  9.     filterdate(2) = "line"
  10.     filtertype(3) = -4
  11.     filterdate(3) = "or>"
  12.     ThisDrawing.Utility.Prompt "选择要偏移的多段线:"
  13.     Dim ft As Variant, fd As Variant
  14.     ft = filtertype: fd = filterdate
  15.     Dim SSet As AcadSelectionSet
  16.     ThisDrawing.SelectionSets("ss1").Delete
  17.     Set SSet = ThisDrawing.SelectionSets.Add("ss1")
  18.     SSet.SelectOnScreen ft, fd
  19. End Sub
 楼主| 发表于 2015-2-3 21:52:07 | 显示全部楼层
zzyong00 发表于 2015-2-3 10:54
你写的这个运行起来可以  ft  和fd开不出来有啥用啊
啥叫开不出来?能运行不比不能运行好吗?实现目的是错吗?早知道如此,我何必呢  发表于 2015-2-3 22:07
发表于 2015-2-4 11:11:01 | 显示全部楼层
zzyong00的解释不对,你的写法是对的,就是多打了空格,见下图
 楼主| 发表于 2015-2-4 12:39:47 | 显示全部楼层
嗯   多谢了 各位  领教
发表于 2015-2-4 13:36:28 | 显示全部楼层
SelectOnScreen 方法
提示用户从屏幕上拾取对象。
语法
object.SelectOnScreen [FilterType][, FilterData]
Object
    SelectionSet
     使用该方法的对象。
FilterType
     Variant[变体](整数数组); 仅用于输入; 可选项
    指定使用的过滤器类型的 DXF 组码。
FilterData
     Variant[变体](变体数组); 仅用于输入; 可选项
     过滤器的值。
发表于 2015-2-4 13:40:10 | 显示全部楼层
  1. 另外:如果仅仅是选多种对象,只需要这样就行!
  2. Public Sub asdf()
  3. On Error Resume Next
  4.     Dim filtertype(0) As Integer
  5.     Dim filterdate(0) As Variant
  6.     filtertype(0) = 0
  7.     filterdate(0) = "lwpolyline,line,arc,circle"
  8.     Dim ft As Variant, fd As Variant
  9.     ft = filtertype: fd = filterdate
  10.     Dim SSet As AcadSelectionSet
  11.     ThisDrawing.SelectionSets("ss1").Delete
  12.     Set SSet = ThisDrawing.SelectionSets.Add("ss1")
  13.     SSet.SelectOnScreen ft, fd
  14. End Sub
GMT+8, 2025-5-26 05:43 , Processed in 0.165213 second(s), 29 queries , Gzip On.
