查看: 1104|回复: 2
[基础] 怎样创建一个新块?
发表于 2015-1-29 16:05:35 | 显示全部楼层 |阅读模式
我要创建一个新块,块里面只有一个圆,我的代码如下,但是没创建起,请大家帮忙看看。谢谢!
    <CommandMethod("A2")>
    Public Sub A2()
        Dim doc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim blockName As String = "asdsadsa"
        Using trans As Transaction = db.TransactionManager.StartTransaction
            Dim ModelSpace As BlockTableRecord = trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
            Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForWrite)
            Dim btr As BlockTableRecord = New BlockTableRecord()
            If Not bt.Has(blockName) Then
                btr.Name = blockName
                Dim clr As New Circle
                clr.Center = New Point3d(100, 100, 0)
                clr.Radius = 40
                ModelSpace.AppendEntity(clr)
                bt.UpgradeOpen()
                bt.Add(btr)
                trans.AddNewlyCreatedDBObject(btr, True)
                bt.DowngradeOpen()
            End If
            trans.Commit()
        End Using
    End Sub
发表于 2015-1-30 14:20:01 | 显示全部楼层
改为 btr.AppendEntity(clr)
发表于 2015-1-30 14:20:42 | 显示全部楼层
另外还要有 trans.AddNewlyCreatedDBObject(cir, True)
GMT+8, 2025-5-23 09:57 , Processed in 0.170277 second(s), 23 queries , Gzip On.
