查看: 1041|回复: 0
net下cad对象动画问题
发表于 2015-1-26 18:33:07 | 显示全部楼层 |阅读模式
大家好,我想做一个在cad里的动态演示,用的timer控制时间,5秒间隔还行,1秒以下cad就挂了为什么?源码如下,求高手帮忙,多谢。
Private Shared Sub OnTimedEvent(source As Object, e As ElapsedEventArgs)
        Dim str As String = "The Elapsed event was raised at {0}" & e.SignalTime
        Dim str2 As String = str
        Dim i As Integer = 0
        Dim id As ObjectId
        For Each id In mBodyId
            intEnd = Now.Ticks
            tsnResult = New TimeSpan(intEnd - intStart)
            Dim tt As Double = Val(tsnResult.TotalMilliseconds.ToString) / 1000
            Dim v As Double = 1
            Dim x As Double = v * tt
            Dim angle As Single = 0
            ChangeBlockRefInsPointAndAngle(id, New Point3d(x, 2 * x + 1, 0), angle)
        Next
End Sub
Public Shared Sub ChangeBlockRefInsPointAndAngle(ByVal BlockRefId As ObjectId, ByVal Newposition As Point3d, ByVal angle As Single)
        Dim acCurDb As Database = HostApplicationServices.WorkingDatabase
        ''启动一个事务   Start a transaction
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            Dim ent As BlockReference = acTrans.GetObject(BlockRefId, OpenMode.ForWrite)
            '' 创建一个矩阵并利用一个矢量将圆从点(0,0,0)移动到点(2,0,0)     Create a matrix and move the circle using a vector from (0,0,0) to (2,0,0)
            Dim acPt3d As Point3d = New Point3d(ent.Position.X, ent.Position.Y, 0)
            Dim acVec3d As Vector3d = acPt3d.GetVectorTo(New Point3d(Newposition.X, Newposition.Y, 0))
            ent.TransformBy(Matrix3d.Displacement(acVec3d))
            '' 保存新对象到数据库中   Save the new objects to the database
            acTrans.Commit()
            Autodesk.AutoCAD.ApplicationServices.Application.UpdateScreen()
        End Using
    End Sub
GMT+8, 2025-5-2 00:44 , Processed in 0.269821 second(s), 25 queries , Gzip On.
