查看: 1068|回复: 5
求助 面域布尔运算 赋值时报错 ——类型不匹配
发表于 2015-1-20 13:45:38 | 显示全部楼层 |阅读模式
  1. Public Sub createcage()
  2. Dim dbpoint As Variant
  3. Dim halfwidth As Double
  4. Dim Hlength As Double
  5. Hlength = 110
  6. Dim outframpoint(0 To 7) As Double
  7. Dim inframpoint(0 To 7) As Double
  8. Dim cagecenter(0 To 2) As Double
  9. Dim cageradius As Double
  10. halfwidth = 255
  11. cageradius = 350
  12. Dim incircle(0 To 0) As AcadCircle
  13. Dim outcircle(0 To 0) As AcadCircle
  14. Dim outfram(0 To 0) As AcadEntity
  15. Dim infram(0 To 0) As AcadEntity
  16. '用户获取点并赋值以方便以后使用
  17. dbpoint = ThisDrawing.Utility.GetPoint(, "Select a point")
  18. cagecenter(0) = dbpoint(0) + 355: cagecenter(1) = dbpoint(1): cagecenter(2) = dbpoint(2)
  19. With ThisDrawing.ModelSpace
  20. Set incircle(0) = .AddCircle(cagecenter, cageradius)
  21. Set outcircle(0) = .AddCircle(cagecenter, cageradius + 5)
  22.
  23. '画外框
  24. outframpoint(0) = dbpoint(0): outframpoint(1) = dbpoint(1) + halfwidth
  25. outframpoint(2) = dbpoint(0) + Hlength: outframpoint(3) = dbpoint(1) + halfwidth
  26. outframpoint(4) = dbpoint(0) + Hlength: outframpoint(5) = dbpoint(1) - halfwidth
  27. outframpoint(6) = dbpoint(0): outframpoint(7) = dbpoint(1) - halfwidth
  28. Set outfram(0) = .AddLightWeightPolyline(outframpoint)
  29. outfram(0).Closed = True
  30. '画内框
  31. inframpoint(0) = dbpoint(0): inframpoint(1) = dbpoint(1) + halfwidth - 5
  32. inframpoint(2) = dbpoint(0) + Hlength: inframpoint(3) = dbpoint(1) + halfwidth - 5
  33. inframpoint(4) = dbpoint(0) + Hlength: inframpoint(5) = dbpoint(1) - halfwidth + 5
  34. inframpoint(6) = dbpoint(0): inframpoint(7) = dbpoint(1) - halfwidth + 5
  35. Set infram(0) = .AddLightWeightPolyline(inframpoint)
  36. infram(0).Closed = True
  37. '面域图形到
  38. Dim regions(0 To 3) As Variant
  39. regions(0) = .AddRegion(outcircle):  regions(1) = .AddRegion(incircle)
  40. regions(2) = .AddRegion(outfram):  regions(3) = .AddRegion(infram)
  41. '将面域复制
  42. Dim A, B, C, D As AcadRegion
  43. Set A = regions(0): Set B = regions(1): Set C = regions(2): Set D = regions(3)
  44. A.Boolean acSubtraction, B: C.Boolean acSubtraction, D
  45. End With
  46. End Sub
 楼主| 发表于 2015-1-20 13:47:59 | 显示全部楼层
将47,50 ,51 加引号注释就运行很好 ,求高手帮忙看看
 楼主| 发表于 2015-1-20 13:49:47 | 显示全部楼层
这个却运行的很好,不知道上面那个程序是哪里错了
  1. Sub Ch4_CreateCompositeRegions()
  2. ' 创建两个圆,一个代表房间,
  3. ' 另外一个为房间中心的柱子
  4. Dim RoomObjects(0 To 1) As AcadCircle
  5. Dim center(0 To 2) As Double
  6. Dim radius As Double
  7. center(0) = 4
  8. center(1) = 4
  9. center(2) = 0
  10. radius = 2#
  11. Set RoomObjects(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
  12. radius = 1#
  13. Set RoomObjects(1) = ThisDrawing.ModelSpace.AddCircle(center, radius)
  14.
  15. ' 用两个圆创建面域
  16. Dim regions As Variant
  17. regions = ThisDrawing.ModelSpace.AddRegion(RoomObjects)
  18. ' 将面域复制到面域变体中以方便使用
  19. Dim RoundRoomObj As AcadRegion
  20. Dim PillarObj As AcadRegion
  21.
  22. If regions(0).Area > regions(1).Area Then
  23. ' 第一个面域为房间
  24. Set RoundRoomObj = regions(0)
  25. Set PillarObj = regions(1)
  26. Else
  27. ' 第一个面域为柱子
  28. Set PillarObj = regions(0)
  29. Set RoundRoomObj = regions(1)
  30. End If
  31.
  32. ' 将房间颜色设为红色,柱子颜色设为青色
  33. RoundRoomObj.color = acRed
  34. PillarObj.color = acCyan
  35. ZoomAll
  36.
  37. ' 从地板空间中减去柱子的空间
  38. ' 以得到代表总的地毯面积的面域。
  39. RoundRoomObj.Boolean acSubtraction, PillarObj
  40.
  41. ' 使用Area属性以确定总的地毯面积
  42. MsgBox "地毯面积为: " & RoundRoomObj.Area
  43. End Sub
 楼主| 发表于 2015-1-20 13:52:15 | 显示全部楼层
 楼主| 发表于 2015-1-20 13:53:22 | 显示全部楼层
程序运行附图
发表于 2015-1-20 15:01:52 | 显示全部楼层
AddRegion返回的是数组/variant
不是数组的成员!!!!
regions(0) = .AddRegion(outcircle) 这当然不对了!
还有Dim A, B, C, D As AcadRegion,把ABC也定义成AcadRegion,而不应该是variant
GMT+8, 2025-5-26 08:31 , Processed in 0.772664 second(s), 24 queries , Gzip On.
