查看: 1059|回复: 2
如何获取多行文字的当前对齐状态?
发表于 2015-1-12 09:17:35 | 显示全部楼层 |阅读模式
我现在有Proe导出的CAD文件,其中有部分文字的对齐状态需要更改。如:左上对齐的文字需更改为左中对齐,右上对齐的文字为右中对齐。
找到了设置文字的对齐样式使用AttachmentPoint,但是获取当前的文字对齐方式怎么弄?求教!
发表于 2015-1-12 09:57:26 | 显示全部楼层
摘自《明经通道 Auto CAD ActiveX 和VBA 参考》
Sub Example_AttachmentPoint()
    Dim MTextObj As AcadMText
    Dim width As Double
    Dim text As String
    Dim count As Integer
    Dim attachPoint As String
    Dim corner(0 To 2) As Double
    corner(0) = 3#: corner(1) = 3#: corner(2) = 0#
    width = 10
    text = "Hello, World."
    ' Creates a MText object in model space
    Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
    For count = 1 To 9
        MTextObj.AttachmentPoint = count
        ' Gets the attachment point of an MText object
        attachPoint = Choose(MTextObj.AttachmentPoint, "TopLeft", "TopCenter", "TopRight", "MiddleLeft", "MiddleCenter", "MiddleRight", "BottomLeft", "BottomCenter", "BottomRight")
        ThisDrawing.Regen True
        MsgBox "The attachment point of the MText is now: " & attachPoint, vbInformation, "AttachmentPoint 示例"
    Next
End Sub
 楼主| 发表于 2015-1-12 21:15:47 | 显示全部楼层
    Dim MTextObj As Aca ...
。。。之前看了好几遍居然没看出来,我居然也从来没试过。谢谢啦!
GMT+8, 2025-7-8 04:31 , Processed in 0.204152 second(s), 27 queries , Gzip On.
