查看: 1387|回复: 0
[JIG] 请问怎样实现在屏幕上指定旋转角度?
发表于 2015-1-1 02:44:49 | 显示全部楼层 |阅读模式
这是我写的?在屏幕上指定旋转角度不会了(现在是错误的) 请指点下
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.GraphicsInterface;
namespace XXXX
  public  class EntJip:DrawJig
        public BlockReference m_blo;
        private Point3d m_pt1, m_pt2;
        public EntJip(Point3d pt1,  BlockReference blo)
            m_pt1 = pt1;//块的插入点
            m_blo = blo;
        protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw)
            draw.Geometry.Draw(m_blo);
            return true;
        protected override SamplerStatus Sampler(JigPrompts prompts)
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            //Matrix3d mt = ed.CurrentUserCoordinateSystem;
            JigPromptPointOptions optJigPoint = new JigPromptPointOptions("\n请制定插入角度:");
            optJigPoint.Cursor = CursorType.NoSpecialCursor;
            optJigPoint.UserInputControls =  UserInputControls.NoZeroResponseAccepted | UserInputControls.NoNegativeResponseAccepted;
            //optJigPoint.BasePoint = m_pt1.TransformBy(mt);//指定块参照的插入点
            optJigPoint.BasePoint = m_pt1;
            optJigPoint.UseBasePoint = true;
            //获得点
            PromptPointResult resJigPoint = prompts.AcquirePoint(optJigPoint);
            Point3d tempt = resJigPoint.Value;
            //拖拽取消
            if (resJigPoint.Status == PromptStatus.Cancel)
                return SamplerStatus.Cancel;
            //进行拖拽
            if (m_pt2 != tempt)
                m_pt2 = tempt;
                m_blo.Position = m_pt1;
                double rotationAngle = m_pt2.AngleFromXAxis(m_pt1);
                m_blo.TransformBy(Matrix3d.Scaling(1, m_pt1) * Matrix3d.Rotation(rotationAngle-rotationAngle, Vector3d.ZAxis, m_pt1));
                return SamplerStatus.OK;
            else
                return SamplerStatus.NoChange;
GMT+8, 2025-5-2 01:12 , Processed in 0.172618 second(s), 24 queries , Gzip On.
