查看: 1682|回复: 0
[基础教程] 求a^N幂方
发表于 2014-11-30 18:46:38 | 显示全部楼层 |阅读模式
;;;求a^N幂方  如(pow 5 10000)将得到6990位的大数
(defun fbin (n)
(setq binlst nil)
(while (> n 0)
    (setq b (rem n 2))
    (setq binlst (cons b binlst))
    (setq n (lsh n -1))
binlst
(defun add (lst1 lst2)
  (setq k1 (length lst1))
  (setq k2 (length lst2))
  (if (> k1 k2)
          (repeat (- k1 k2)  (setq lst2 (cons 0 lst2)) )
          (repeat (- k2 k1)  (setq lst1 (cons 0 lst1)) )
  (setq addlst (mapcar '(lambda (x y) (+ x y)) lst1 lst2 ))
  addlst
(defun lnum (lst n n0)
   (setq lst (mapcar '(lambda (x) (* x n))  lst))
   (setq zlst (reverse lst))
   (repeat n0 (setq zlst (cons 0 zlst) ) )
(reverse zlst)
(defun xc(lst1 lst2)
   (setq n1 (length lst1))
   (setq n2 (length lst2))
   (setq j 1 fflst '(0))
   (if (> n1 n2)
          (while (<= j n2)
              (setq fflst (add (lnum lst1 (nth (- j 1) lst2) (- n2 j) ) fflst))
              (setq j (+ 1 j))
          (while (<= j n1)
              (setq fflst (add (lnum lst2 (nth (- j 1) lst1) (- n1 j) ) fflst))
              (setq j (+ 1 j))
fflst
(defun jinw (blst)
    (while (not (apply 'and (mapcar '(lambda (x) (<= x 9)) blst )))
         (setq hlst (mapcar '(lambda (x) (rem x 10)) blst))
         (setq qlst (mapcar '(lambda (x) (/ x 10)) blst))
         (setq qlst (append qlst (list 0)))
         (setq blst (add hlst qlst))
  blst
(defun sr (a)
   (setq n (strlen a) i 1 lst nil)
   (while (<= i n)
        (setq lst (cons (atoi (substr a i 1)) lst))
        (setq i (+ 1 i))
   (reverse lst)
(defun dc (a b)
  (setq lst1 (sr a))
  (setq lst2 (sr b))
  (setq tenlst (jinw (xc lst1 lst2)))
  (setq str (apply 'strcat (mapcar '(lambda (x) (itoa x)) tenlst ) ) )
  (if (= (car tenlst) 0)
      (setq str (vl-string-left-trim "0" str))
str
(defun pow (x n)
   (setq x (itoa x))
   (if (= (rem n 2) 0) (setq y "1")(setq y x))
   (setq binlst (cdr (reverse (fbin n))))
   (setq xlst (mapcar '(lambda (i) (setq x (dc x x)))  binlst))
   (setq ylst (mapcar '(lambda (i j) (if (= i 1) (setq y (dc y j)))) binlst xlst))
   (last ylst)
(pow 5 10000)
USER2128 + 1 很给力!
GMT+8, 2025-5-2 05:07 , Processed in 0.160267 second(s), 25 queries , Gzip On.
