查看: 1524|回复: 1
关于teigha例子c#转成vb.net的一个问题
发表于 2014-11-25 11:40:01 | 显示全部楼层 |阅读模式
由于不会c#,就把代码转换成vb.net。在线转的。但转化后总出问题。以下是一个类代码。请大家帮我看看。
  1. class SR : SelectionReactor
  2.   {
  3.     ObjectIdCollection selected;
  4.     ObjectId spaceId;
  5.     public SR(ObjectIdCollection s, ObjectId id)
  6.     {
  7.       spaceId = id;
  8.       selected = s;
  9.     }
  10.     public override bool Selected(DrawableDesc pDrawableDesc)
  11.     {
  12.       DrawableDesc pDesc = pDrawableDesc;
  13.       if (pDesc.Parent != null)
  14.       {
  15.         // we walk up the GS node path to the root container primitive
  16.         // to avoid e.g. selection of individual lines in a dimension
  17.         while (((DrawableDesc)pDesc.Parent).Parent != null)
  18.           pDesc = (DrawableDesc)pDesc.Parent;
  19.         if (pDesc.PersistId != IntPtr.Zero && ((DrawableDesc)pDesc.Parent).PersistId == spaceId.OldIdPtr)
  20.         {
  21.           pDesc.MarkedToSkip = true; // regen abort for selected drawable, to avoid duplicates
  22.           selected.Add(new ObjectId(pDesc.PersistId));
  23.         }
  24.         return true;
  25.       }
  26.       return false;
  27.     }
  28.     // this more informative callback may be used to implement subentities selection
  29.     public override SelectionReactorResult Selected(PathNode pthNode, Teigha.GraphicsInterface.Viewport viewInfo)
  30.     {
  31.       return SelectionReactorResult.NotImplemented;
  32.     }
  33.   };
复制代码
转成vb.net的代码
  1. Class SR
  2.     Inherits SelectionReactor
  3.         Private <font color="#ff0000">Shadows</font> selected As ObjectIdCollection
  4.     Private spaceId As ObjectId
  5.     Public Sub New(s As ObjectIdCollection, id As ObjectId)
  6.       spaceId = id
  7.             Selected = s
  8.     End Sub
  9.         'Public Overrides Function Selected(pDrawableDesc As DrawableDesc) As Boolean
  10.         Public Overloads Function Selected(ByVal pDrawableDesc As DrawableDesc) As Boolean
  11.             Dim pDesc As DrawableDesc = pDrawableDesc
  12.             If pDesc.Parent IsNot Nothing Then
  13.                 ' we walk up the GS node path to the root container primitive
  14.                 ' to avoid e.g. selection of individual lines in a dimension
  15.                 While DirectCast(pDesc.Parent, DrawableDesc).Parent IsNot Nothing
  16.                     pDesc = DirectCast(pDesc.Parent, DrawableDesc)
  17.                 End While
  18.                 If pDesc.PersistId <> IntPtr.Zero AndAlso DirectCast(pDesc.Parent, DrawableDesc).PersistId = spaceId.OldIdPtr Then
  19.                     pDesc.MarkedToSkip = True
  20.                     ' regen abort for selected drawable, to avoid duplicates
  21.                     selectedc.Add(New ObjectId(pDesc.PersistId))
  22.                 End If
  23.                 Return True
  24.             End If
  25.             Return False
  26.         End Function
  27.         ' this more informative callback may be used to implement subentities selection
  28.         Public Overrides Function Selected(ByVal pthNode As PathNode, ByVal viewInfo As Teigha.GraphicsInterface.Viewport) As SelectionReactorResult
  29.             Return SelectionReactorResult.NotImplemented
  30.         End Function
  31.     End Class
shodows本来是没有的。建议我加。我加上还是不行。提示如下
错误        1        “Selected”已声明为此 class 中的“Private Shadows selected As Teigha.DatabaseServices.ObjectIdCollection”。        H:\source code\dmdraw\dmdraw\SelectionReactor.vb        114        35        dmdraw
错误        2        “Selected”已声明为此 class 中的“Private Shadows selected As Teigha.DatabaseServices.ObjectIdCollection”。        H:\source code\dmdraw\dmdraw\SelectionReactor.vb        132        35        dmdraw
有哪位熟悉两种代码的吗。应该怎么处理呢。
发表于 2015-3-16 10:23:36 | 显示全部楼层
vb.net 不区分大小写,c#是区分的,在vb.net中变量selected 和Selected 函数冲突了
GMT+8, 2025-5-2 13:58 , Processed in 0.152610 second(s), 23 queries , Gzip On.
