查看: 916|回复: 1
call调用函数怎么不行啊 求救 跪求大神啊
发表于 2014-11-22 16:37:31 | 显示全部楼层 |阅读模式
Public Sub addentstosset(ByVal ents As Variant, ByRef sset As AcadSelectionSets)
   Dim objcollection() As AcadEntity
   ReDim objcollection(UBound(ents))
   If VarType(ents) <> vbArray + vbArray Then
     MsgBox "数据无效!"
    End If
    For i = 0 To UBound(ents)
        objcollection(i) = ents(i)
        Next i
   sset.AddItems objcollection
End Sub
Sub creat()
  Dim sset As AcadSelectionSet
  On Error Resume Next
  If Not IsNull(ThisDrawing.SelectionSets.Item("example")) Then
    Set sset = ThisDrawing.SelectionSets.Item("example")
    sset.Delete
End If
Set sset = ThisDrawing.SelectionSets.Add("example")
Dim pt(0 To 2) As Double
pt(0) = 0
pt(1) = 0
pt(2) = 0
Dim cirl1 As AcadCircle, cirl2 As AcadCircle, cirl3 As AcadCircle
Set cirl1 = ThisDrawing.ModelSpace.AddCircle(pt, 50)
Set cirl2 = ThisDrawing.ModelSpace.AddCircle(pt, 80)
Set cirl3 = ThisDrawing.ModelSpace.AddCircle(pt, 110)
Dim objcollection(0 To 2) As AcadEntity
Set objcollection(0) = cirl1
Set objcollection(1) = cirl2
Set objcollection(2) = cirl3
Call addentstosset(objcollection, sset)
MsgBox sset.Count
sset.Delete
End Sub
发表于 2014-11-22 22:57:34 | 显示全部楼层
常识 ByVal ents As Variant,Variant不能用byval传值方式
GMT+8, 2025-5-26 08:40 , Processed in 0.163377 second(s), 23 queries , Gzip On.
