查看: 1221|回复: 1
[基础] 在下想将与多段线相交的圆删除,总是不理想,请高手帮忙看下!感激不尽!
发表于 2014-10-25 22:42:16 | 显示全部楼层 |阅读模式
Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = HostApplicationServices.WorkingDatabase;
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            TypedValueList value1 = new TypedValueList();
            value1.Add(typeof(Circle));
            SelectionFilter filter1 = new SelectionFilter(value1);
            PromptSelectionResult psr1 = ed.GetSelection(filter1);
            if (psr1.Status != PromptStatus.OK)
            { return; }
            SelectionSet ss1 = psr1.Value;
            TypedValueList value2 = new TypedValueList();
            value2.Add(typeof(Polyline));
            SelectionFilter filter2 = new SelectionFilter(value2);
            PromptSelectionResult psr2 = ed.GetSelection(filter2);
            if (psr2.Status != PromptStatus.OK)
            { return; }
            SelectionSet ss2 = psr2.Value;
            ObjectIdCollection obc1 = new ObjectIdCollection();
            foreach (ObjectId id1 in ss1.GetObjectIds())
                obc1.Add(id1);
            ObjectIdCollection obc2 = new ObjectIdCollection();
            foreach (ObjectId id2 in ss2.GetObjectIds())
                obc2.Add(id2);
            Point3dCollection intpoints = new Point3dCollection ();
            int  m = 2;int n = -2;
            ObjectIdCollection obc = new ObjectIdCollection();
            using (Transaction trans = db.TransactionManager.StartTransaction())
            for (int i = 0; i < obc1.Count; i++)
                Circle cir = trans.GetObject(obc1[i], OpenMode.ForRead) as Circle;
                for (int j = 0; j < obc2.Count; j++)
                    Polyline pl = trans.GetObject(obc2[j], OpenMode.ForRead) as Polyline;
                    pl.IntersectWith(cir, Intersect.OnBothOperands, intpoints,m, n);
                    //Point3d pt = cir.Center;
                    //pl.GetDistAtPoint(pt)<cir.Radius
                    if (intpoints.Count>0)
                        obc.Add(cir.ObjectId);
                        //cir.Erase(true);
            for (int i = 0; i < obc.Count;i++ )
                Circle ci = trans.GetObject(obc[i], OpenMode.ForWrite) as Circle;
                ci.Erase(true);
            trans.Commit();
发表于 2014-10-26 07:06:16 来自手机 | 显示全部楼层
点pline->取模拟点->由点表构造过滤器为Circle的 F 选择
GMT+8, 2025-5-2 06:48 , Processed in 0.157849 second(s), 23 queries , Gzip On.
