查看: 2203|回复: 5
[表格] 求教:如何合并单元格
发表于 2014-10-21 20:18:39 | 显示全部楼层 |阅读模式
初学C#开发AutoCAD,想使用MergeCells函数对“表格”图元的单元格进行合并,请问应该如何做?
发表于 2014-10-23 16:30:45 | 显示全部楼层
需要定制可联系我,qq:379539186
发表于 2020-2-8 11:54:28 | 显示全部楼层
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
namespace TableStyleEditing
  public class Commands
    [CommandMethod("UTT")]
    public void UnmergeTableTitle()
      var doc = Application.DocumentManager.MdiActiveDocument;
      if (doc == null) return;
      var ed = doc.Editor;
      // Select a table
      var peo = new PromptEntityOptions("\nSelect table");
      peo.SetRejectMessage("\nMust be a table.");
      peo.AddAllowedClass(typeof(Table), false);
      var per = ed.GetEntity(peo);
      if (per.Status != PromptStatus.OK)
        return;
      using (var tr = doc.TransactionManager.StartTransaction())
        var table = tr.GetObject(per.ObjectId, OpenMode.ForWrite) as Table;
        if (table != null)
          // Get the first row
          var row = table.Rows[0];
          // If it is merged, unmerge it
          if (row.IsMerged.HasValue && row.IsMerged.Value)
            table.UnmergeCells(row);
            ed.WriteMessage("\nUnmerged first row.");
          else
            ed.WriteMessage("\nFirst row is not merged.");
        tr.Commit();
发表于 2020-2-8 11:55:42 | 显示全部楼层
     var row = table.Rows[0];是取的第一行的区域,如何定义何意区域
发表于 2020-2-8 14:04:56 | 显示全部楼层
Tb.MergeCells(ROWS(1))'行合并;   Tb.MergeCells(Tb.Columns(2))'列合并;可是任意的单位格区域怎么定义呢
发表于 2020-2-14 20:50:30 | 显示全部楼层
protected CellRange(
    Table table,
    int topRow,
    int leftColumn,
    int bottomRow,
    int rightColumn
public virtual void MergeCells(
    CellRange range
传入一个CellRange对象,要合并的行的收尾索引和要合并列的首尾索引。
GMT+8, 2025-5-1 16:22 , Processed in 0.187895 second(s), 28 queries , Gzip On.
