查看: 1464|回复: 5
编译错误,求高手支招!代码已附,看正文
发表于 2014-10-19 12:30:28 | 显示全部楼层 |阅读模式
我用快捷命令运行,以前能用,最近不懂怎么了,运行就提示"编译错误---不支持的对象库功能"
新手发帖,求大神支招。
Public Sub DGX_GC()
    Dim DGX_1 As AcadLWPolyline
    Dim DGX_2 As AcadPolyline
    Dim Point1 As Variant
    Dim Point2 As Variant
    ThisDrawing.SetVariable "osmode", 0
    ThisDrawing.SetVariable "osmode", 512
    Point1 = ThisDrawing.Utility.GetPoint(, "请选择第一条等高线:")
    Dim SET1 As AcadSelectionSet
    Dim SET2 As AcadSelectionSet
    Dim S1 As String
    Dim S2 As String
    S1 = "DGX1": S2 = "DGX2"
    On Error Resume Next
    If Not IsNull(ThisDrawing.SelectionSets.Item(S1)) Then
        Set SET1 = ThisDrawing.SelectionSets(S1)
        SET1.Delete
    End If
    If Not IsNull(ThisDrawing.SelectionSets.Item(S2)) Then
        Set SET2 = ThisDrawing.SelectionSets(S2)
        SET2.Delete
    End If
    Set SET1 = ThisDrawing.SelectionSets.Add(S1)
    Set SET2 = ThisDrawing.SelectionSets.Add(S2)
    Dim F_type(4) As Integer
    Dim F_data(4)  As Variant
    F_type(0) = -4: F_data(0) = "<or"
    F_type(1) = 0: F_data(1) = "LWPOLYLINE"
    F_type(2) = 0: F_data(2) = "POLYLINE"
    F_type(3) = -4: F_data(3) = "or>"
    F_type(4) = 8: F_data(4) = "DGX"
    SET1.SelectAtPoint Point1, F_type, F_data
    Dim GC1 As Double
    Dim GC2 As Double
    If SET1.Item(0).ObjectName = "AcDbPolyline" Then
        Set DGX_1 = SET1.Item(0)
        DGX_1.Highlight True
        GC1 = DGX_1.Elevation
    ElseIf SET1.Item(0).ObjectName = "AcDb2dPolyline" Then
        Set DGX_2 = SET1.Item(0)
        DGX_2.Highlight True
        GC1 = DGX_2.Elevation
    End If
    Point2 = ThisDrawing.Utility.GetPoint(, "请选择第二条等高线:")
    SET2.SelectAtPoint Point2, F_type, F_data
    If SET2.Item(0).ObjectName = "AcDbPolyline" Then
        Set DGX_1 = SET2.Item(0)
        GC2 = DGX_1.Elevation
        Set DGX_2 = SET2.Item(0)
        GC2 = DGX_2.Elevation
    End If
    Dim Point3 As Variant
    Point3 = ThisDrawing.Utility.GetPoint(, "请点击选择高程生成位置:")
    Dim C1 As Double
    Dim C2 As Double
    C1 = ((Point1(0) - Point3(0)) ^ 2 + (Point1(1) - Point3(1)) ^ 2) ^ 0.5
    C2 = ((Point2(0) - Point1(0)) ^ 2 + (Point2(1) - Point1(1)) ^ 2) ^ 0.5
    Dim GCC As Double '高程差
    GCC = (GC1 - GC2) * (C1 / C2)
    Dim GCZ As Double
    GCZ = GC1 - GCC
    ThisDrawing.SendCommand "DRAWGCD" & Space(1) & 1 & Space(1) & Point3(0) & "," & Point3(1) & Space(1) & GCZ & vbCrLf
    DGX_1.Highlight False
    DGX_2.Highlight False
    SET1.Delete
    SET2.Delete
End Sub
 楼主| 发表于 2014-10-23 00:23:32 | 显示全部楼层
沙发自己坐!大神们来帮帮忙!
发表于 2014-10-23 06:54:30 | 显示全部楼层
发错地方了,这是LISP板块。
 楼主| 发表于 2014-10-23 09:09:41 | 显示全部楼层
ZZXXQQ 发表于 2014-10-23 06:54
发错地方了,这是LISP板块。
版主,应该在哪个板块发?
发表于 2014-10-23 11:18:41 | 显示全部楼层
你这代码应该是没问题的,
DRAWGCD不是系统命令,但这不会引起那个问题
你的错误不应该在这个sub里
 楼主| 发表于 2014-10-25 12:19:23 | 显示全部楼层
zzyong00 发表于 2014-10-23 11:18
你这代码应该是没问题的,
你的错误不应该在这个sub里
大神帮分析一下具体原因可否?
没有具体的东西,怎么分析具体的原因?  发表于 2014-10-25 14:23
GMT+8, 2025-5-26 12:17 , Processed in 0.177612 second(s), 25 queries , Gzip On.
