查看: 1103|回复: 1
请教为何无法选择?
发表于 2014-9-28 11:27:41 | 显示全部楼层 |阅读模式
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using System;
using System.Collections.Generic;
using System.Text;
using System.Collections;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Geometry;
using Application = Autodesk.AutoCAD.ApplicationServices.Application;
using Document = Autodesk.AutoCAD.ApplicationServices.Document;
using System.Linq;
using System.Diagnostics;
namespace ClassLibrary5
    public class Class1
        [CommandMethod("SEL")]
        public void sel()
            Autodesk.AutoCAD.EditorInput.Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            SelectionFilter acSelFtr = new SelectionFilter(new TypedValue[] {
                     new TypedValue((int)DxfCode.Operator, "<or"),
                        new TypedValue((int)DxfCode.Start, "DIMENSION") ,
                        new TypedValue((int)DxfCode.Start, "insert") ,
                        new TypedValue((int)DxfCode.Operator, ">or")
            PromptSelectionResult res2 = ed.GetSelection(acSelFtr);
            if (res2.Status != PromptStatus.OK)
                return;
            else
                ed.SetImpliedSelection(res2.Value.GetObjectIds());
加载后,运行SEL,命令不执行,如果我把过滤条件改成单个,可以正常选择,请教老大们是哪里出了问题?
 楼主| 发表于 2014-9-28 11:42:58 | 显示全部楼层
哎原来是这句写错了new TypedValue((int)DxfCode.Operator, ">or"); 应该是"or>"!我这个大晕蛋
GMT+8, 2025-5-2 04:17 , Processed in 0.152386 second(s), 27 queries , Gzip On.
