查看: 1156|回复: 3
求助 添加图形词典数据后,无法保存文件
发表于 2014-9-25 23:20:34 | 显示全部楼层 |阅读模式
       小弟今日通过如下方法给图纸添加词典后,图纸竟然无法保存,实在不解,求老大们指点
public static void AddDictionary(string Dicname, string XrecordName, object val)
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                DBDictionary NOD = trans.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForWrite) as DBDictionary;
                DBDictionary Dict;
                try
                    Dict = (DBDictionary)trans.GetObject(NOD.GetAt(Dicname), OpenMode.ForWrite);
                catch
                    Dict = new DBDictionary();
                    NOD.SetAt(Dicname, Dict);
                    trans.AddNewlyCreatedDBObject(Dict, true);
                // 通过Xrecord和ResultBuffer添加扩展数据
                Xrecord xRec=new Xrecord();
                System.Type tp = val.GetType();
                try
                    xRec = (Xrecord)trans.GetObject(Dict.GetAt(XrecordName), OpenMode.ForWrite);
                catch
                finally
                    if (tp == typeof(int))
                        xRec.Data = new ResultBuffer(new TypedValue((int)DxfCode.ExtendedDataInteger32, val));
                    else if (tp == typeof(string))
                        xRec.Data = new ResultBuffer(new TypedValue((int)DxfCode.ExtendedDataAsciiString, val));
                    else
                        xRec.Data = new ResultBuffer(new TypedValue((int)DxfCode.ExtendedDataReal, val));
                    Dict.SetAt(XrecordName, xRec);
                   // trans.AddNewlyCreatedDBObject(xRec, true);
                    trans.Commit();
发表于 2014-9-26 08:23:25 来自手机 | 显示全部楼层
看这里最后部分
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=76123
 楼主| 发表于 2014-9-26 10:22:39 | 显示全部楼层
谢谢老大,原来必须要加这句           NOD.UpgradeOpen();
发表于 2014-9-26 10:45:22 来自手机 | 显示全部楼层
不是这句 是后面那句
GMT+8, 2025-5-2 06:43 , Processed in 0.158827 second(s), 29 queries , Gzip On.
