查看: 1472|回复: 5
谁有Ribbon菜单的程序啊,或者讲讲怎么弄
发表于 2014-8-23 20:55:42 | 显示全部楼层 |阅读模式
我测试了下论坛上的例子,似乎老是报错。我用得是cad2012和vs2010
发表于 2014-9-5 10:53:39 | 显示全部楼层
顶!同求啊!
发表于 2014-9-5 21:45:44 来自手机 | 显示全部楼层
用局部cui吧
 楼主| 发表于 2014-9-8 10:30:53 | 显示全部楼层
我也测试了深入浅出AutoCAD.NET二次开发,用cad2012和vs2010,发现还是不行,有高手指点一二?
  1. /////////////////////////////////////////////////////////////////////////////////////////////////
  2. //http://www.bimcad.org 数字建筑
  3. //深入浅出AutoCAD二次开发(李冠亿)
  4. /////////////////////////////////////////////////////////////////////////////////////////////////
  5. using System;
  6. using Autodesk.Windows;
  7. using Autodesk.AutoCAD.Runtime;
  8. [assembly: CommandClass(typeof(Sample.CH6_3_5))]
  9. namespace Sample
  10. {
  11.     class CH6_3_5
  12.     {
  13.         [CommandMethod("AddRibbon")]
  14.         public void AddRibbon()
  15.         {
  16.             RibbonControl rc = RibbonControl();
  17.             RibbonTab rt = RibbonTab("菜单标签", "1");
  18.             RibbonPanel rp = RibbonPanel("菜单面板");
  19.             RibbonButton rb = RibbonButton("菜单按钮", "菜单命令");
  20.             rp.Source.Items.Add(rb);
  21.             rt.Panels.Add(rp);
  22.             rc.Tabs.Add(rt);
  23.         }
  24.         /// <summary>
  25.         /// 获得菜单控制
  26.         /// </summary>
  27.         /// <returns></returns>
  28.         public static RibbonControl RibbonControl()
  29.         {
  30.             if (Autodesk.Windows.ComponentManager.Ribbon == null)
  31.                 Autodesk.Windows.ComponentManager.ItemInitialized += new EventHandler<RibbonItemEventArgs>(ComponentManager_ItemInitialized);
  32.             return ComponentManager.Ribbon; //Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSet.RibbonControl; //
  33.         }
  34.         /// <summary>
  35.         /// 创建菜单标签
  36.         /// </summary>
  37.         /// <param name="Name">标签名</param>
  38.         /// <param name="id">标签ID</param>
  39.         /// <returns></returns>
  40.         public static RibbonTab RibbonTab(string Name, string id)
  41.         {
  42.             RibbonTab ribTab = new Autodesk.Windows.RibbonTab();
  43.             ribTab.Title = Name;
  44.             ribTab.Id = id;
  45.             ribTab.IsActive = true;
  46.             return ribTab;
  47.         }
  48.         /// <summary>
  49.         /// 创建菜单面板
  50.         /// </summary>
  51.         /// <param name="Title">面板名</param>
  52.         /// <returns></returns>
  53.         public static RibbonPanel RibbonPanel(string Title)
  54.         {
  55.             RibbonPanelSource ribSourcePanel = new RibbonPanelSource(); // Autodesk.Windows
  56.             ribSourcePanel.Title = Title;//now the panel
  57.             RibbonPanel ribPanel = new RibbonPanel();
  58.             ribPanel.Source = ribSourcePanel;
  59.             return ribPanel;
  60.         }
  61.         /// <summary>
  62.         /// 创建菜单按钮
  63.         /// </summary>
  64.         /// <param name="btName">按钮名</param>
  65.         /// <param name="cmdName">命令名</param>
  66.         /// <returns></returns>
  67.         public static RibbonButton RibbonButton(string btName, string cmdName)
  68.         {
  69.             RibbonButton ribButton = new RibbonButton();
  70.             ribButton.Text = btName;
  71.             ribButton.CommandParameter = cmdName;
  72.             ribButton.ShowText = true;
  73.             ribButton.CommandHandler = new AdskCommandHandler();
  74.             return ribButton;
  75.         }
  76.         /// <summary>
  77.         /// 用于激活菜单
  78.         /// </summary>
  79.         /// <param name="sender"></param>
  80.         /// <param name="e"></param>
  81.         static void ComponentManager_ItemInitialized(object sender, RibbonItemEventArgs e)
  82.         {
  83.             if (Autodesk.Windows.ComponentManager.Ribbon != null)
  84.                 Autodesk.Windows.ComponentManager.ItemInitialized -= new EventHandler<RibbonItemEventArgs>(ComponentManager_ItemInitialized);
  85.         }
  86.         /// <summary>
  87.         /// 执行按钮的命令
  88.         /// </summary>
  89.         public class AdskCommandHandler : System.Windows.Input.ICommand
  90.         {
  91.             /// <summary>
  92.             /// 是否可执行(接口)
  93.             /// </summary>
  94.             /// <param name="parameter">命令名</param>
  95.             /// <returns></returns>
  96.             public bool CanExecute(object parameter)
  97.             {
  98.                 return true;
  99.             }
  100.             /// <summary>
  101.             /// 改变可执行状态
  102.             /// </summary>
  103.             public event EventHandler CanExecuteChanged;
  104.             /// <summary>
  105.             /// 执行命令
  106.             /// </summary>
  107.             /// <param name="parameter">命令的名字</param>
  108.             public void Execute(object parameter)
  109.             {
  110.                 //is from a Ribbon Button?
  111.                 RibbonButton ribBtn = parameter as RibbonButton;
  112.                 if (ribBtn != null)
  113.                     Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.SendStringToExecute((String)ribBtn.CommandParameter, true, false, true);
  114.                 //is from s Ribbon Textbox?
  115.                 RibbonTextBox ribTxt = parameter as RibbonTextBox;
  116.                 if (ribTxt != null)
  117.                     System.Windows.Forms.MessageBox.Show(ribTxt.TextValue);
  118.             }
  119.         }
  120.     }
  121. }
发表于 2014-9-9 11:44:03 | 显示全部楼层
我也试了这个例子,可以啊!
发表于 2025-2-26 08:49:22 | 显示全部楼层
我也想了解下,同求啊
GMT+8, 2025-5-1 09:57 , Processed in 0.198016 second(s), 28 queries , Gzip On.
