查看: 1486|回复: 5
vb.net调用lisp文件
发表于 2014-7-11 15:53:34 | 显示全部楼层 |阅读模式
请大神给段代码
发表于 2014-7-11 17:53:45 | 显示全部楼层
C#的版本
        [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl)]
        extern static private int acedInvoke(IntPtr args, out IntPtr result);
        public static ResultBuffer CallLispFunction(ResultBuffer args)
            IntPtr ip = IntPtr.Zero;
            int st = acedInvoke(args.UnmanagedObject, out ip);
            if (ip != IntPtr.Zero)
                ResultBuffer rbRes = ResultBuffer.Create(ip, true);
                return rbRes;
            return null;
        public static ResultBuffer CallLispFunction(string name, params object[] args)
            ResultBuffer rbArgs = new ResultBuffer();
            rbArgs.Add(new TypedValue((int)LispDataType.Text, name));
            foreach (object val in args)
                AddValueToResultBuffer(ref rbArgs, val);
            return CallLispFunction(rbArgs);
发表于 2014-7-11 17:54:44 | 显示全部楼层
        private static void AddValueToResultBuffer(ref ResultBuffer rb, object obj)
            if (obj == null)
                rb.Add(new TypedValue((int)LispDataType.Text, ""));
            else
                if (obj is string)
                    rb.Add(new TypedValue((int)LispDataType.Text, obj));
                else if (obj is Point2d)
                    rb.Add(new TypedValue((int)LispDataType.Text, "_non"));
                    rb.Add(new TypedValue((int)LispDataType.Point2d, obj));
                else if (obj is Point3d)
                    rb.Add(new TypedValue((int)LispDataType.Point3d, obj));
                else if (obj is ObjectId)
                    rb.Add(new TypedValue((int)LispDataType.ObjectId, obj));
                else if (obj is SelectionSet)
                    rb.Add(new TypedValue((int)LispDataType.SelectionSet, obj));
                else if (obj is double)
                    rb.Add(new TypedValue((int)LispDataType.Double, obj));
                else if (obj is short)
                    rb.Add(new TypedValue((int)LispDataType.Int16, obj));
                else if (obj is int)
                    rb.Add(new TypedValue((int)LispDataType.Int32, obj));
                else if (obj is TypedValue)
                    rb.Add(obj);
 楼主| 发表于 2014-7-12 15:09:11 | 显示全部楼层
要在VB.NET中写一段可以调用lisp程序的代码。能否给个VB代码。
发表于 2014-7-12 19:12:15 | 显示全部楼层
自己转换一下吧 呵呵
VB.NET--->C#
地址(C#---> VB.NET):
http://www.developerfusion.co.uk/utilities/convertcsharptovb.aspx
地址( VB.NET--->C#):
http://www.developerfusion.co.uk/utilities/convertvbtocsharp.aspx
 楼主| 发表于 2014-7-17 10:50:34 | 显示全部楼层
雪山飞狐_lzh 发表于 2014-7-12 19:12
自己转换一下吧 呵呵
VB.NET--->C#
谢谢大神的帮助
GMT+8, 2025-5-2 06:42 , Processed in 0.158022 second(s), 24 queries , Gzip On.
