查看: 13257|回复: 15
[2015] AutoCAD 2015 SP1 已经发布了,建议立即升级
发表于 2014-6-11 10:49:44 | 显示全部楼层 |阅读模式
发表于 2014-6-11 11:09:19 | 显示全部楼层
有什么功能呀,介绍一下.
 楼主| 发表于 2014-6-11 23:46:12 | 显示全部楼层
Autodesk AutoCAD 2015 and AutoCAD LT 2015       Service Pack 1 Readme
          Thank you for downloading Autodesk AutoCAD® 2015 and AutoCAD LT® 2015 Service Pack             1
This readme contains the latest information regarding the installation and use of the Service Pack. We strongly recommend that you read the entire document before you apply the Service Pack  to your product. For reference, you save or print this document.
Contents
Who Should Install This Service Pack?
You can apply this  Service Pack to the following Autodesk products running on all supported operating systems and languages. Be sure to install the correct Service Pack  for your software.
32-bit Product
Service Pack
Autodesk AutoCAD 2015AutoCAD_2015_SP1_32bit.exe
Autodesk AutoCAD LT 2015AutoCAD_LT_2015_SP1_32bit.exe
64-bit Product
Service Pack
Autodesk AutoCAD 2015AutoCAD_2015_SP1_64bit.exe
Autodesk AutoCAD LT 2015AutoCAD_LT_2015_SP1_64bit.exe
This Service Pack can be applied to AutoCAD 2015 and AutoCAD LT 2015 installed as a standalone application as well as AutoCAD 2015 and AutoCAD LT 2015 installed from the following suites or bundled products.
  • Autodesk AutoCAD Design Suite 2015
  • Autodesk AutoCAD Inventor LT Suite 2015
  • Autodesk AutoCAD Revit LT Suite 2015
  • Autodesk AutoCAD with Advance Steel 2015
  • Autodesk Building Design Suite 2015
  • Autodesk Factory Design Suite 2015
  • Autodesk Infrastructure Design Suite 2015
  • Autodesk Plant Design Suite 2015
  • Autodesk Product Design Suite 2015
Primary Issues Resolved by This Service Pack
Problems Reported with the Customer Error Reporting Utility
As a result of the detailed information that we received from customers who used the Customer Error Reporting Utility, several problems were identified and fixed. Updates have been made in the following commands and features:
DB Connect
  • Occasional crashes when using DB Connect feature on 64-bit machines     with 4GB and more RAM.
Status Bar
  • Occasional crashes when opening drawing file when a bubble notification     is still displayed.
New Tab
  • Occasional crashes when clicking New in the Quick Access Toolbar or the     Start Drawing tile on the New Tab page.
  • Occasional crashes when clicking the New Tab Plus button after adding     LayerFilterComboControl or Filter in the CUI dialog box.
Design Center
  • Occasional crashes when inserting a block from Design Center on the     second time.
General
  • Occasional crashes when selecting the "Fully open the drawing file"     option that displays when opening a drawing that was saved in the partial     open state.
  • Occasional crashes when exiting AutoCAD.
General Service Pack Updates
The following defects have been fixed:
3D Modeling
  • Using the ViewCube dropdown for selecting a saved UCS will not accept     UCS names that contain a space.
  • The SCALE command is not applied correctly for scale factors less than     1/100th.
Display
  • Cursor trails will display on the screen for users with Optimus or     Dynamic Switchable Graphics technology.
Hatch
  • Lineweight is applied and displayed for solid hatch objects.
  • Additional lines display in the selection highlighting for a solid     hatch object.
  • Hatch objects do not apply LAYLOCKFADECTL or XDWGFADECTL.
  • The angle of a gradient changes the appearance of that gradient.
  • Solid hatch objects display the edge color.
Plot
  • ViewCube will appear on plots under certain conditions.
VBA
  • Unable to execute SendCommand API in multiple drawings.
General
  • The number of recently used files accepts a maximum of 10. The maximum     has been restored to 50.
Security Hotfix
  • This Service Pack includes the Autodesk AutoCAD Security Hotfix.  This Service Pack can     be applied whether that security hotfix was originally applied to your     system or not.
  • If you have Autodesk ReCap 2015 installed together with AutoCAD 2015,     please install Autodesk ReCap 2015 Hotfix 1 via Autodesk Application     Manager.
New CURSORBADGE System Variable
CURSORBADGE (System Variable)
Controls the display of visual aide badges near the cursor.
Type: Integer
Saved in: Registry
Initial value: 2
1 - Turn off all new badges
2 - Turn on all badges (Default)
Badges that will be disabled:
  • Selection - cross and window selection
  • Inspection
  • Deletion
  • Copy
  • Move
  • Rotate
  • Scale
  • Zoom
  • Add vertex
  • Covert to arc
  • Hatch inherit property
General Installation Information
Note: The Autodesk 360 (AdSync) patch will automatically be installed with the AutoCAD and AutoCAD LT Service Pack.
Before You Begin
As you prepare to install this Service Pack, keep the following in mind:
Back Up Custom Files
   We recommend that you back up all custom CUIX, MNR, and MNL files before   you apply this Service Pack.
Administrative Privileges
  During installation, you will be prompted for the original installation   media or a network image. To apply this Service Pack, you must have   administrative privileges to install and uninstall products.
Network Deployment
  Administrators can deploy this Service Pack over a network using the   Deployment Wizard.
About Your Product
  After you install the Service Pack,  updated product information will   display in the About dialog box.
Reboot
  After you install this Service Pack, we recommend that you reboot your   system even if you are not prompted.
About Windows Command Line Switches
The following  Microsoft Windows command line switches are built into this Service Pack:
  • /e - Extracts the MSP file from the Service Pack executable file.
  • /q - Suppresses the completion message after the Service Pack is applied.    This is useful if you use a script or batch file to apply this Service Pack to    multiple computers.
Instructions about how to use the /e command line switch are included in the installation procedures that follow.
Installation Instructions
Apply This Service Pack to a Stand-Alone Installation
Follow these instructions to install this Service Pack on a single computer.
  • Download this Service Pack and save it to any folder.
  • If required, insert the product media (for example, the AutoCAD   installation disc).
  • Find the folder where you saved the Service Pack and double-click the    executable (EXE) file.
Apply This Service Pack Through a Local Network
Follow these instructions to install this Service Pack on multiple computers using your local network.
  • Download this Service Pack and save it to any shared folder on your local   network.
  • Find the shared folder where you saved the Service Pack, and double-click   the executable (EXE) file.
Note: Installation through your local network using the CAD Manager Control Utility is not supported for this Service Pack.
Apply This Service Pack to a Network Administrative Image
The following distribution method applies only to administrative images created with the Deployment wizard. After you complete these procedures, subsequent deployments of your product will include this Service Pack.
In all cases, append this Service Pack to the deployment. The only time it is appropriate to merge the Service Pack is if you intend to distribute the deployment through a group policy object.
The patch (Service Pack) file that you download contains an MSP (Microsoft Patch) file, which you extract from the executable file using the /e (extract) switch.
  • From the Autodesk Product Support website, download the Service Pack EXE   file to your local computer.
  • On the Start menu (Windows), click Run. Enter the following information   and click OK.       <local_drive:>\<patch_name> /e   <local_drive:>\< patch_name>.msp
  • Insert the Autodesk media and launch setup.exe.
  • Select Create Deployments. Click Next.
  • On the Begin Deployment page, in the Specify the Deployment Location box,   enter the shared network location where you would like to create an   administrative image, or click Browse to find a location. Users will install   the product from this location.
  • In the Specify a Deployment Name box, enter the name for your deployment.
  • Continue  through the Deployment wizard, open and configure the deployment   in the product configuration page, click Add to find the Service Pack   extracted in Step 2.  Notice that the Service Pack has been added in the   Include Service Pack(s) from Local Drive or Local Network box. Close and   return to the product list.
  • Follow the instructions in the Deployment wizard to complete the Service   Pack deployment.
Note: The extraction of MSP from the service pack executable requires VC++ runtime redistributable 2012. Please make sure it is installed before extracting the MSP file.
Uninstall This Service Pack
Windows 7 / Windows 8
  • Start Control Panel.
  • Click Programs.
  • Click Programs and Features.
  • In the Programs and Features window, in the left pane, click View   Installed Updates.
  • Find the appropriate Service Pack in the list of updates. Click Uninstall.
Thank You
We want to express our appreciation to all our customers who identified these issues and reported them to us. Their reports gave us the opportunity to improve the product for everyone's benefit. We also thank you for your continued business, and for your feedback regarding this release.
Respectfully,
The Autodesk AutoCAD and AutoCAD LT Product Team
Copyright &#169;2014 Autodesk, Inc.
发表于 2014-6-12 00:08:19 | 显示全部楼层
下载地址贴一下。http://knowledge.autodesk.com/su ... service-pack-1.html
这次更新这么早呀,说明2015还是有很多问题的呀。近几年的版本都是8-9月份出第一个更新的呀
 楼主| 发表于 2014-6-12 11:49:55 | 显示全部楼层
其实应该不断更新才好。
发表于 2014-6-13 12:36:24 | 显示全部楼层
更新真快啊
发表于 2014-6-13 15:49:59 | 显示全部楼层
需要什么配置啊
发表于 2014-6-15 22:23:50 | 显示全部楼层
中文版的更新还没发布啊
发表于 2014-6-24 15:03:53 | 显示全部楼层
不错 下载了安装 多谢
发表于 2014-7-3 15:55:08 | 显示全部楼层
更新的这么快,2015用着还是没有2014稳定的感觉
GMT+8, 2025-5-18 03:42 , Processed in 0.210578 second(s), 29 queries , Gzip On.
