楼主: slw7310
已知 圆弧的半径 起始角 终止角 圆心坐标 求凸度(正负)
 楼主| 发表于 2014-5-21 16:29:06 | 显示全部楼层
谢谢高手指点!!
发表于 2014-5-22 14:39:18 | 显示全部楼层
 楼主| 发表于 2014-5-22 22:23:18 | 显示全部楼层
谢谢指导!
发表于 2021-6-28 11:20:27 | 显示全部楼层
  1. ;取圆弧凸度-------------yjtdkj by 2021.06
  2. (defun c:tt ()
  3.   (progn
  4.   (defun yj-dxf (key ename) (cdr (assoc key (entget ename))))
  5.   (defun mid (p1 p2)
  6.       (mapcar (function (lambda (e1 e2) (* (+ e1 e2) 0.5))) p1 p2)
  7.     )
  8.     )
  9.   (setq en (car (entsel)))
  10.   (setq
  11.   r     (dxf 40 en)
  12.   pt1   (vlax-curve-getstartPoint en)
  13.   pt2   (vlax-curve-getEndPoint en)
  14.   ptm   (mid pt1 pt2)
  15.   len   (vlax-curve-getDistAtPoint en (vlax-curve-getEndPoint en))
  16.   cpm   (vlax-curve-getpointAtdist en (/ len 2))
  17.   dis   (distance pt1 pt2)
  18.   h     (distance ptm cpm)
  19.   )
  20.   (setq tu (/ h (* dis 0.5)))
  21.   (setq
  22.     a (-(cadr pt2) (cadr pt1))
  23.     b (-(car pt1)(car pt2))
  24.     c (-(* -1 a (car pt1))(* b (cadr pt1)))
  25.     d1 (-(* -1 a (car cpm))(* b (cadr cpm)))
  26.   )
  27.   (cond
  28.     ((= d1 c)
  29.       (* tu 0)
  30.   )
  31.   ((> d1 c)
  32.       (* tu -1)
  33.   )
  34.   ((< d1 c)
  35.       (* tu 1)
  36.   )
  37. )
  38. )
GMT+8, 2025-5-1 14:33 , Processed in 0.174416 second(s), 17 queries , Gzip On.
