[已解答] 【多段线坐标问题】
 楼主| 发表于 2014-5-6 17:32:45 | 显示全部楼层
kwok 发表于 2014-5-6 15:15
看看这个是不是,只加了可以输入xyz.
CAD启动指令:   tqzb
感谢大神,问题圆满解决。麻烦各位了!向每位回答的表示感谢!
发表于 2014-5-6 17:37:44 | 显示全部楼层
玉麒麟卢比奥 发表于 2014-5-6 16:59
谢谢!我刚试了半天,不知道应该把这句话加在循环的哪一行。。。大大能不能帮到底,今天晚上交接,实在没 ...
试试:
  1. ;;46.2 [功能] pline,lwpline点坐标表  By 无痕;;示例(vxs (car (entsel))),返回三维点坐标
  2. (defun vxs (e / i v lst)
  3.   (setq i -1)
  4.   (while
  5.     (setq v (vlax-curve-getpointatparam e (setq i (1+ i))))
  6.      (setq lst (cons v lst))
  7.   )
  8.   (reverse lst)
  9. )
  10. ---------------------------------------------------------
  11. ;;;;;;;;;三维顶点输出到文本
  12. (defun c:tqzb (/ ss en ii ptb no pz)
  13.   (vl-load-com)
  14.   (setq cm (getvar "cmdecho"))
  15.   (setvar "cmdecho" 0)
  16.   (setq wjm (getfiled "请指定要保存的坐标文件" "e:\\" "txt" 1))
  17.   (setq fff (open wjm "w"))
  18.   (setq ss (ssget '((0 . "lwPOLYLINE"))))
  19.   (setq ii 0
  20.         no 0
  21.   )
  22.   (repeat (sslength ss)
  23.     (setq en  (ssname ss ii)
  24.           ii  (1+ ii)
  25.           ptb (vxs en)
  26.           pz (cdr (assoc 38 (entget en)))
  27.     )
  28.     (foreach pt ptb
  29.       (setq no (1+ no))
  30.       (write-line
  31.         (strcat                         ;(itoa no) ","
  32.           (rtos (car pt) 2 2)
  33.           ","
  34.           (rtos (cadr pt) 2 2)
  35.           ","
  36.           (rtos pz 2 2)
  37.           ","
  38.         )
  39.         fff
  40.       )
  41.     )
  42.     (write-line "" fff)
  43.   )
  44.   (close fff)
  45.   (princ (strcat "\n坐标已存入\"" wjm "\"中"))
  46.   (setvar "cmdecho" cm)
  47.   (princ)
  48. )
发表于 2015-10-13 16:33:29 | 显示全部楼层
谢谢分享!!!!!!!!!!!!!!!
GMT+8, 2025-7-17 00:01 , Processed in 0.180614 second(s), 18 queries , Gzip On.
