查看: 1278|回复: 0
各位老大,VB中用AddMenuItem调用SUB可以吗?
发表于 2014-4-14 08:40:14 | 显示全部楼层 |阅读模式
各位老大,VB中用AddMenuItem调用SUB可以吗?下面是我在VB中的代码
Option Explicit
Public SAPCAD As AcadApplication
Sub Main()
  On Error Resume Next
    Set SAPCAD = GetObject(, "AutoCAD.Application")
    If Err Then
       Err.Clear
       Set SAPCAD = CreateObject("AutoCAD.Application")
       If Err Then
         MsgBox ("请安装CAD")
         Exit Sub
       End If
     End If
   SAPCAD.WindowState = acMax
   Dim currmenugroup As AcadMenuGroup
   Set currmenugroup = SAPCAD.Application.MenuGroups.Item(0)
   '创建新菜单
   Dim newmenu As AcadPopupMenu
   Set newmenu = currmenugroup.Menus.Add("SAP接口1")
   '在新菜单上增加菜单项
   Dim newmenuitem1 As AcadPopupMenuItem
   Dim newmenuitem2 As AcadPopupMenuItem
   Dim SubMacro As String
   SubMacro = Chr(3) & Chr(3) & Chr(95) & "call Create_bom" & Chr(32)
   Set newmenuitem1 = newmenu.AddMenuItem(newmenu.Count + 1, "根据BOM生成明细表", SubMacro)
   Set newmenuitem2 = newmenu.AddMenuItem(newmenu.Count + 1, "根据明细表生成BOM", SubMacro)
   newmenu.InsertInMenuBar (SAPCAD.Application.MenuBar.Count + 1)
End Sub
Sub Select_material()
Dim s As String
MsgBox "select material"
End Sub
Sub Create_bom()
Dim s As String
MsgBox "select BOM"
End Sub
这样处理后,在CAD中菜单可以出来,可以点了菜单行后没有运行sub Create_bom,有劳老大们指点一下,谢谢!
该贴已经同步到 billyang99的微博
GMT+8, 2025-5-26 07:56 , Processed in 0.174076 second(s), 24 queries , Gzip On.
