- 积分
- 15626
- 明经币
- 个
- 注册时间
- 2013-1-16
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
1明经币
下面的是一个填充的程序,现在缺了一个dHATCH的子程序,实在不知道该怎么写了。
主程序;
(Defun C:2 (/ id ls1 ls2 ls3 ls4 bl bl1 bl2)
(setvar "cmdecho" 0)
(setvar "blipmode" 0)
(command "LAYER" "m" "$DXFH" "")
(setq id (load_dialog "2.DCL")
ls1 (list "i1" "i2" "i3" "i4" "i5" "i6" "i7" "i8" "i9" "i10"
"i11" "i12")
ls2 (list "DX(GH7)" "DX(GH8)" "DX(GH9)"
"DX(GH10)" "DX(GH11)" "DX(GH12)"
"DX(GH13)" "DX(GH15)" "DX(GH14)"
"DX(GH16)" "DX(GH17)" "DX(GH18)"
ls3 (list "i1" "i2" "i3" "i4" "i5" "i6" "i7" "i8")
ls4 (list "DX(GH30)" "DX(GH31)" "DX(GH32)"
"DX(GH33)" "DX(GH34)" "DX(GH35)"
bl1 (list "GT4" "GT1" "GT2" "GT3" "GT5" "GT7"
"GT10" "GT11" "GT6" "HL1" "HL2" "GT12"
bl2 (list "AR-SAND" "AR-CONC" "STONE" "STONE1"
"ANSI31" "ER-SAND" "HL1" "HL2"
(while (/= s1 0)
(if (and (= s1 20) (/= s1 13))
(progn (if (not (new_dialog "DX2" id))
(exit)
(mapcar '(lambda (x y) (ima x y)) ls3 ls4)
(setq bl bl2)
(progn (if (not (new_dialog "DX" id))
(exit)
(mapcar '(lambda (x y) (ima x y)) ls1 ls2)
(setq bl bl1)
(action_tile "i1" "(done_dialog 1)")
(action_tile "i2" "(done_dialog 2)")
(action_tile "i3" "(done_dialog 3)")
(action_tile "i4" "(done_dialog 4)")
(action_tile "i5" "(done_dialog 5)")
(action_tile "i6" "(done_dialog 6)")
(action_tile "i7" "(done_dialog 7)")
(action_tile "i8" "(done_dialog 8)")
(action_tile "i9" "(done_dialog 9)")
(action_tile "i10" "(done_dialog 10)")
(action_tile "i11" "(done_dialog 11)")
(action_tile "i12" "(done_dialog 12)")
(action_tile "Next" "(done_dialog 20)")
(action_tile "Last" "(done_dialog 13)")
(action_tile "cancel" "(done_dialog 0)")
(setq s1 (start_dialog))
(if (and (>= s1 1) (<= s1 12))
(set2 (nth (1- s1) bl))
(setvar "clayer" "0")
(setq s1 nil)
(unload_dialog id)
(Defun ima (a b / x y)
(setq x (dimx_tile a)
y (dimy_tile a)
(start_image a)
(fill_image 0 0 x y 0)
(slide_image 0 0 x y b)
(end_image)
(Defun set2 (a / s1 b p1 p2 ss)
(if (not (new_dialog "DX1" id))
(exit)
(action_tile "accept" "(setq b (get_tile \"B\")k (get_tile \"EP\")) (done_dialog 1)")
(action_tile "ry" "(setq b (get_tile \"B\")k (get_tile \"EP\")) (done_dialog 3)" )
(action_tile "tc" "(setq b (get_tile \"B\") k (get_tile \"EP\")) (done_dialog 2)" )
(action_tile "cancel" "(setq b (get_tile \"B\")) (done_dialog 0)")
(if (> s1 0)
(cond
((= s1 1)
(initget 1)
(setq p1 (getpoint "\n填充区域第一角:"))
(initget 1)
(setq p2 (getcorner p1 "\n另一角:"))
(command "Pline"
p1
(list (car p1) (cadr p2))
p2
(list (car p2) (cadr p1))
"C"
(dHATCH a
(atof b)
0
(setq e (entlast))
(if (= k "1")
T
nil
(command "ERASE" E "")
((= s1 3)
(princ "\n绘填充轮廓线:")
(setvar "plinewid" 0)
(setvar "cecolor" "1")
(command "pline")
(initget 1)
(setq p1 (getpoint "\n第一点:")
ls '(("STONE1" 10) ("ANSI31" 10) ("AR-CONC" 1) ("AR-SAND" 5))
pl (list p1)
s 2
(command p1)
(while
(initget "U C")
(and s
(setq
p2 (getpoint
(car pl)
"\n下一点 / U 回退一步 / C 闭合 / Enter 结束:"
(command p2)
(if (= p2 "C")
(setq s nil)
(if (listp p2)
(setq pl (cons p2 pl))
(setq pl (cdr pl))
(if s
(command "c")
(setvar "cecolor" "bylayer")
(setq e (entlast))
(dHATCH A
(atof b)
0
e
(if (= k "1")
T
nil
((= s1 2)
(princ "\n选取图形为填充区域边界.")
(GC)
(setq ss (ssget))
(if ss
(dHATCH A
(atof b)
0
ss
(if (= k "1")
T
nil
(setq s 0)
DCL:
DX : dialog {
label = "地形图案示意";
: text_part {
label = "选择填充的地形符号";
: row {
: image_button {
key = "i1";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i2";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i3";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i4";
width = 12;
aspect_ratio = 1;
: row {
: text_part {
label = " 草地";
: text_part {
label = " 旱田一";
: text_part {
label = " 旱田二";
: text_part {
label = " 水田";
: row {
: image_button {
key = "i5";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i6";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i7";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i8";
width = 12;
aspect_ratio = 1;
: row {
: text_part {
label = " 树林";
: text_part {
label = " 竹林";
: text_part {
label = " 果园(苹果)";
: text_part {
label = " 果园(梨)";
: row {
: image_button {
key = "i9";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i10";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i11";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i12";
width = 12;
aspect_ratio = 1;
: row {
: text_part {
label = " 灌木";
: text_part {
label = " 横向水流";
: text_part {
label = " 纵向水流";
: text_part {
label = " 泥浆、沼泽";
spacer_1;
: row {
spacer_1;
: cancel_button {
label = "剖面形式";
key = "Next";
spacer_1;
: cancel_button {
label = "退出";
key = "cancel";
spacer_1;
DX2 : dialog {
label = "剖面地形图案示意";
: text_part {
: row {
: image_button {
key = "i1";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i2";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i3";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i4";
width = 12;
aspect_ratio = 1;
: row {
: text_part {
label = " 砂土";
: text_part {
label = " 混凝土";
: text_part {
label = " 毛石";
: text_part {
label = " 砌片石";
: row {
: image_button {
key = "i5";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i6";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i7";
width = 12;
aspect_ratio = 1;
: image_button {
key = "i8";
width = 12;
aspect_ratio = 1;
: row {
: text_part {
label = " 普通土";
: text_part {
label = " 沙砾土";
: text_part {
label = " 横向水流";
: text_part {
label = " 纵向水流";
spacer_1;
: row {
spacer_1;
: cancel_button {
label = "平面形式";
key = "Last";
spacer_1;
: cancel_button {
label = "退出";
key = "cancel";
spacer_1;
DX1 : dialog {
label = "填充操作";
initial_focus = "B";
: row {
: edit_box {
label = "填充比例: ";
edit_width = 6;
key = "B";
value = "10";
: toggle {
label = "打碎图案";
key = "EP";
value = "1";
: boxed_row {
label = "选择添充区域";
spacer_1;
: ok_button {
label = "矩形区域";
key = "accept";
spacer_1;
: button {
label = "任意区域";
key = "ry";
spacer_1;
: button {
label = "图形区域";
key = "tc";
spacer_1;
: cancel_button {
label = "退出";
key = "cancel";
