查看: 1816|回复: 0
[基础习题] 图元原地复制变色到。原图层名加后缀
发表于 2014-4-7 09:36:26 | 显示全部楼层 |阅读模式
  1. (defun c:tt ()        ; 图元原地复制变色到。原图层名加后缀
  2.   (VL-LOAD-COM)
  3.   (setq ss (car (entsel "\n 只能单选图元")))
  4.   (setq ss-en (entget ss))
  5.   (setq  AcadObject   (vlax-get-acad-object)
  6.   AcadDocument (vla-get-ActiveDocument AcadObject)
  7.   mSpace       (vla-get-ModelSpace AcadDocument)
  8.   )
  9.   (setq LayerSel (vla-get-Layers AcadDocument))
  10.   (setq  testLayer (vla-add LayerSel
  11.          (STRCAT
  12.            (cdr (assoc 8 ss-en)
  13.            )
  14.            "--复制"
  15.          )
  16.       )
  17.   )
  18.   (setq mm (vla-get-Name testLayer))
  19.   (command "copy" ss "" '(0 0) "")
  20.   (command "chprop"
  21.      (entlast)
  22.      ""
  23.      "la"
  24.      (vla-get-Name testLayer)
  25.      "C"
  26.      "6"
  27.      ""
  28.   )
  29.   (princ)
  30. )
GMT+8, 2025-5-2 04:49 , Processed in 0.165456 second(s), 29 queries , Gzip On.
