查看: 1398|回复: 3
求助 VBA中坐标转换问题
发表于 2014-3-22 20:58:48 | 显示全部楼层 |阅读模式
以下是一段简单的vba程序代码
Sub Example_AddPolyline()
    ' This example creates a polyline in model space.
    Dim plineObj As AcadPolyline
    Dim points(0 To 14) As Double
    ' Define the 2D polyline points
    points(0) = 1: points(1) = 1: points(2) = 0
    points(3) = 1: points(4) = 2: points(5) = 0
    points(6) = 2: points(7) = 2: points(8) = 0
    points(9) = 3: points(10) = 2: points(11) = 0
    points(12) = 4: points(13) = 4: points(14) = 0
    ' Create a lightweight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
    ZoomAll
End Sub
上面的程序是在cad本身的世界坐标系下生成的一条多段线,现在本人在cad中通过ucs命令移动了坐标系的原点,请问怎么样修改上面的程序使其在自己定义的坐标系下生成所需要的这条多段线呢?
请高手多指教!!!
发表于 2014-3-23 11:37:43 | 显示全部楼层
第一种方法:将顶点坐标数组逐点由UCS转换为WCS,再画线
  1. Sub Example_AddPolyline()
  2.     ' This example creates a polyline in model space.
  3.     Dim plineObj As AcadPolyline
  4.     Dim points(0 To 14) As Double
  5.     ' Define the 2D polyline points
  6.     points(0) = 1: points(1) = 1: points(2) = 0
  7.     points(3) = 1: points(4) = 2: points(5) = 0
  8.     points(6) = 2: points(7) = 2: points(8) = 0
  9.     points(9) = 3: points(10) = 2: points(11) = 0
  10.     points(12) = 4: points(13) = 4: points(14) = 0
  11.
  12.     Dim P1(2) As Double, P2 As Variant, I As Integer
  13.     For I = 0 To 12 Step 3
  14.         P1(0) = points(I): P1(1) = points(I + 1): P1(2) = points(I + 2)
  15.         P2 = ThisDrawing.Utility.TranslateCoordinates(P1, acUCS, acWorld, 0)
  16.         points(I) = P2(0): points(I + 1) = P2(1): points(I + 2) = P2(2)
  17.     Next
  18.     ' Create a lightweight Polyline object in model space
  19.     Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
  20.     ZoomAll
  21. End Sub
第二种方法:先按WCS画线,再将其移动到UCS的相应位置.这种方法要求UCS要命名
  11.     ' Create a lightweight Polyline object in model space
  12.     Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
  13.
  14.     plineObj.TransformBy ThisDrawing.UserCoordinateSystems("UCS名称").GetUCSMatrix
  15.     ZoomAll
  16. End Sub
 楼主| 发表于 2014-3-26 20:26:50 | 显示全部楼层
谢谢高手的指点!能否直接points数组直接从WCS转换到UCS?
发表于 2014-4-18 10:32:00 | 显示全部楼层
占个位置,有时间学习
GMT+8, 2025-5-26 12:05 , Processed in 0.151416 second(s), 23 queries , Gzip On.
