帖子
查看: 3046|回复: 2
[2014] 如何求任意平面多边形的中心点
发表于 2014-3-21 09:28:00 | 显示全部楼层 |阅读模式
各位高手,如何用CAD命令求任意平面多边形的中心点
发表于 2021-12-28 06:49:10 | 显示全部楼层
通过搜索搞定。
思路是把多边形转换成面域 region, 再通过获取面域的参数得到中心点。
(defun C:xingxin()
(setq en (car(entsel "\n选取闭合曲线:")))
;(setvar "DELOBJ" 1)
(if ( /= (get-dxf 0 en) "REGION")
(command "region" en "")
(setq en (entlast))
));if
(setq
ENT (vlax-ename->vla-object en)
CEN (vlax-get ENT "centroid")
AREA (vlax-get ENT "AREA"))
(princ (strcat "\narea: " (rtos area 2 3)))
(princ (strcat "\ncentroid: " (vl-princ-to-string cen )))
(command "point" CEN )
(defun get-DXF (code ename )
(cond ((= (type ename) 'ENAME)
      (if        (= code -3)
      (cdr (assoc code (entget ename '("*"))))
      (cdr (assoc code (entget ename)))
  );COND
GMT+8, 2025-7-12 10:39 , Processed in 0.200739 second(s), 28 queries , Gzip On.
