查看: 1460|回复: 2
跪求高手,谁能帮忙看下这个程序那里有问题啊加载后输入BSB提示不确定的对象绑定T
发表于 2014-3-17 20:31:53 | 显示全部楼层 |阅读模式
(defun c:BSB (/ OLDOS p0 p1 p0x p0y p1x p1y xi yi pc txi tyi t);测量矩形并生成文本
(COMMAND "UNDO" "BE")
(SETQ OLDLN (GETVAR "CLAYER"))
(SETQ OLDOS(GETVAR "OSMODE"))
(initget 1)
(setq p0 (getpoint "\nFirst Point:"))
(initget 33)
(setq p1 (getcorner p0 "\nSecond Point:"))
(SETQ p0x (NTH 0 P0))
(SETQ p0y (NTH 1 P0))
(SETQ p1x (NTH 0 P1))
(SETQ p1y (NTH 1 P1))
(SETQ xi (- p1x p0x))
(SETQ yi (- p1y p0y))
(if (and p0 p1)
(setq pc (polar p0 (angle p0 p1) (/ (distance p0 p1) 2)))
(setq txi (RTOS (abs xi) 2 0))
(setq tyi (RTOS (abs yi) 2 0))
(SETVAR "OSMODE" 0)
(if (ssget "w" p0 p1)(command "erase" "p" ""))
(if (> (abs xi) (abs yi))
(COMMAND "TEXT" "j" "m" pc "50" "0" t)
(COMMAND "TEXT" "j" "m" pc "50" "90" t)
(SETVAR "OSMODE" OLDOS)
(SETVAR "CLAYER" OLDLN)
(COMMAND "UNDO" "E")
(PRINC)
发表于 2014-3-17 21:33:03 | 显示全部楼层
(setq t (STRCAT tYi " BSB " tXi))
不要用T當變數
 楼主| 发表于 2014-3-18 08:14:28 | 显示全部楼层
楼上的钻石会员还是 牛 啊 哈哈我在t后面又加了个y,可以了 谢谢了LSJJ
GMT+8, 2025-5-3 03:54 , Processed in 0.257451 second(s), 28 queries , Gzip On.
