查看: 1315|回复: 1
[基础] 谁来帮我看看这段代码出了什么问题!!
发表于 2014-2-12 20:46:54 | 显示全部楼层 |阅读模式
Public Class Form1
    Dim AutoCADApp As Object
    Dim Thisdrawing As Object
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        If AutoCADApp Is Nothing Then
            If Err.Number <> 0 Then Err.Clear()
            AutoCADApp = GetObject(, "AutoCAD.Application")
                Err.Clear()
                Exit Sub
            End If
        Else
            Thisdrawing = AutoCADApp.ActiveDocument()
            '创建组
            Dim ObjGroup As Object
            Dim Objentity() As Object
            Dim InserMText As Object
            ObjGroup = Thisdrawing.Groups.Add("*")
            ReDim Objentity(0 To 3)
            Dim pt(0 To 2) As Double
            With Thisdrawing.ModelSpace
                For i = 0 To 3
                    pt(0) = 1 : pt(1) = 2 * i : pt(2) = 0
                    InserMText = .AddText(i, pt, 1)
                    Objentity(i) = InserMText
                Next
                ObjGroup.AppendItems(Objentity)
            End With
        End If
    End Sub
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
            Err.Clear()
            Exit Sub
        End If
    End Sub
End Class
运行到这句话就报警ObjGroup.AppendItems(Objentity)
 楼主| 发表于 2014-2-12 20:48:48 | 显示全部楼层
我觉得我很不了解VB.net的object对象!!谁能深入讲解一下吗?
GMT+8, 2025-5-2 15:48 , Processed in 0.169846 second(s), 25 queries , Gzip On.
