查看: 4471|回复: 7
文字加前后缀
发表于 2013-10-26 09:52:52 | 显示全部楼层 |阅读模式
(DEFUN C:LT005 ()
(setq qh (getint "\n======加前缀输入(1),  ======加后缀输入(2),  <1>:"))
(if (= qh nil)(setq qh 1))
(princ "\nselect object:")
(setq ss (ssget))
(setq str (getstring "\n请输入要加的文字:"))
(setq n (sslength ss))
(setq k 0 )
(while (< k n)
      (setq name (ssname ss k))
      (setq a (entget name))
      (setq t1 (assoc '0 a))
      (setq t1 (cdr t1))
      (if (= t1 "TEXT") (PROGN
        (setq h (assoc '1 a))
发表于 2014-1-3 16:42:36 | 显示全部楼层
完了?好像没结束吧?
发表于 2014-3-25 11:06:25 | 显示全部楼层
好像没结束吧
发表于 2016-3-15 17:50:42 | 显示全部楼层
好像没结束吧
发表于 2023-3-5 09:06:35 | 显示全部楼层
执行之后CAD未响应,这插件哪位大神再优化下(测试版本:CAD2010)
(DEFUN C:kk ()
(setq ss (ssget))
(setq k 0 )
(while (< k n)
(setq t1 (cdr t1))
发表于 2023-3-5 12:21:57 | 显示全部楼层
已经有网友提供相应的了,版权归原发帖人!
;; 前缀后缀
(defun c:qaa ()
  (setq qhz (getint "\n加前缀-1,加后缀-2,减前缀-3,减后缀-4,<1>"))
  (if (= qhz nil)
    (setq qhz 1)
  (if (or (= qhz 1) (= qhz 2))
    ((princ "\n选择修改对象:")
      (setq s (ssget))
      (setq str (getstring "\n输入要加的字:"))
      (setq n (sslength s))
      (setq k 0)
      (while (< k n)
        (setq name (ssname s k))
        (setq t1 (cdr t1))
        (if (= t1 "TEXT")
          (PROGN
            (setq hh (cdr h))
            (if        (= qhz 1)
              (setq str1 (strcat str hh))
            (if        (= qhz 2)
              (setq str1 (strcat hh str))
            (setq h1 (cons 1 str1))
                                        ;(if (= str "") (setq h1 h))
            (setq a (subst h1 h a))
            (entmod a)
        (setq k (+ k 1))
  (if (and (/= c 1) (/= c 2))
      (setq s (ssget))
      (princ "一个汉字占两个字符")
      (setq nnn (getint "输入要减的字符数量<1>:"))
      (if (= nnn nil)
        (setq nnn 1)
      (setq k 0)
      (while (< k n)
        (setq t1 (cdr t1))
        (if (= t1 "TEXT")
          (PROGN
            (setq hh (cdr h))
            (setq len0 (strlen hh)
                  len1 (- len0 nnn)
            (if        (= qhz 3)
              (setq str1 (substr hh (+ 1 nnn) len1))
            (if        (= qhz 4)
              (setq str1 (substr hh 1 len1))
            (entmod a)
        (setq k (+ k 1))
;; 前缀后缀
;仿贱人前后缀
;(qianhouzhuiset)
(defun qianhouzhuiset ( / get_date lst_str str file f dcl_id dd);通过对话框设置参数
(defun get_date ()(mapcar 'get_tile(list "qz" "qztx" "hz" "hztx")))
(setq lst_str '(
"qianhouzhuidcl:dialog {label = \"前后缀\" ;"
"    :boxed_column {label = \"选项\" ;"
"        :row{:toggle {key = \"qz\" ;label = \"前缀\" ;}"
"             :edit_box {edit_width = 30 ;key = \"qztx\" ;}}"
"        :row{:toggle {key = \"hz\" ;label = \"后缀\" ;}"
"             :edit_box {edit_width = 30 ;key = \"hztx\" ;}}"
"   :row{: button{label = \"加前后缀\";key = \"button1\";}"
"        : button{label = \"删前后缀\";key = \"button2\";}"
"         cancel_button;}"
"    :text {label = \"by mike\" ;}}"
    (setq file (vl-filename-mktemp "DclTemp.dcl"))
    (setq f (open file "w"))
    (foreach str lst_str(princ "\n" f)(princ str f))
    (close f)
    (or qianhouzhuidata(setq qianhouzhuidata(list "1" "1)" "0" "。")));全局变量
(setq dcl_id (load_dialog file))
(new_dialog "qianhouzhuidcl" dcl_id "3" Pset_qhzdate)
(mapcar '(lambda (x y) (set_tile x y))(list "qz" "qztx" "hz" "hztx")qianhouzhuidata)
(action_tile "button1" "(setq qianhouzhuidata(get_date))(setq Pset_qhzdate(done_dialog 1)))")
(action_tile "button2" "(setq qianhouzhuidata(get_date))(setq Pset_qhzdate(done_dialog 2)))")
(setq dd (start_dialog))
(unload_dialog dcl_id)
(vl-file-delete file);删除临时dcl文件
(cond((= 1 dd)(cons "+" qianhouzhuidata))((= 2 dd)(cons "-" qianhouzhuidata))(t nil))
(defun c:qaaa()(setq qhzset(qianhouzhuiset))(qianhouzhui qhzset)(princ))
;qhzset固定格式,对话框输出的
(defun qianhouzhui(qhzset / qhz- data ss txtls qz hz)
(defun qhz- (str str1 str2)
  (if(wcmatch str (strcat str1 "*"))(setq str(substr str(1+(strlen str1)))))
  (if(wcmatch str (strcat "*"  str2))(setq str(substr str 1(- (strlen str)(strlen str2)))))
  str
(sssetfirst);防已选误操作
(setq ss0(ssadd))
(while
  (setq ss(ssget ":S" '((0 . "*TEXT")
   (-4 . "<NOT")(1 . "*\\P*")(-4 . "NOT>")
   (-4 . "<NOT")(1 . "*\n*")(-4 . "NOT>")
   (-4 . "<NOT")(1 . "*\t*")(-4 . "NOT>")
  )));只有一行的文字
  (setq ss(mapcar 'cadr (ssnamex ss)))
  (setq ss(vl-remove-if '(lambda(x)(/= (type x) 'ENAME))ss));变图元名表
  (setq ss(vl-remove-if '(lambda(x)(ssmemb x ss0))ss));不在ss0的
  (cond(ss(mapcar '(lambda(x)(setq ss0(ssadd x ss0))) ss);加入ss0
    (setq ss(mapcar 'vlax-ename->vla-object ss));对象集
    (setq txtls(mapcar 'vla-get-textstring ss));字符串表
    (setq qz(if(= "1"(nth 1 qhzset))(nth 2 qhzset)""))
    (setq hz(if(= "1"(nth 3 qhzset))(nth 4 qhzset)""))
    (if(= "+" (car qhzset))
     (setq txtls(mapcar '(lambda(x)(strcat qz x hz))txtls))
     (setq txtls(mapcar '(lambda(x)(qhz- x qz hz))txtls))
    (mapcar '(lambda(x y)(vla-put-textstring x y))ss txtls)
发表于 2023-7-1 18:22:02 | 显示全部楼层
;; 前缀后缀
感谢分享,测试ok,很适合批次文本修改使用。
GMT+8, 2025-5-24 09:44 , Processed in 0.457469 second(s), 22 queries , Gzip On.
