帖子
查看: 1509|回复: 2
请教版主、高手,多字(mtext)vba程序实现居中怎样处理?
发表于 2013-10-22 16:58:39 | 显示全部楼层 |阅读模式
请教版主、高手,多字(mtext)vba程序实现居中怎样处理?单行文字使用Alignment,多行文字不知怎样处理,谢谢!
 楼主| 发表于 2013-10-22 17:08:40 | 显示全部楼层
Sub Example_AttachmentPoint()
    Dim MTextObj As AcadMText
    Dim width As Double
    Dim text As String
    Dim count As Integer
    Dim attachPoint As String
    Dim corner(0 To 2) As Double
    corner(0) = 3#: corner(1) = 3#: corner(2) = 0#
    width = 10
    text = "Hello, World."
    ' Creates a MText object in model space
    Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
    For count = 1 To 9
        MTextObj.AttachmentPoint = count
        ' Gets the attachment point of an MText object
        attachPoint = Choose(MTextObj.AttachmentPoint, "TopLeft", "TopCenter", "TopRight", "MiddleLeft", "MiddleCenter", "MiddleRight", "BottomLeft", "BottomCenter", "BottomRight")
        ThisDrawing.Regen True
        MsgBox "The attachment point of the MText is now: " & attachPoint, vbInformation, "AttachmentPoint Example"
    Next
End Sub
 楼主| 发表于 2013-10-23 10:09:58 | 显示全部楼层
mtxt.AttachmentPoint = AcAttachmentPoint.acAttachmentPointMiddleCenter  '多行文字居中
GMT+8, 2025-7-14 05:02 , Processed in 0.151674 second(s), 25 queries , Gzip On.
