查看: 2841|回复: 5
PLT打印任务代码报错问题,求高手指点啊
发表于 2013-10-17 16:25:19 | 显示全部楼层 |阅读模式
在执行打印任务,保存plt文件的代码中,pPlotProgDlg->setPlotMsgString(AcPlPlotProgressDialog::kDialogTitle,_T("lot API Progress"));这行代码时即报错,,不知啥原因,急求高手指点啊。(注:代码中标红部分即为开始报错的地方)
Acad::ErrorStatus es;
es = m_pPSV->setPlotType(m_pPlotSettings, AcDbPlotSettings::kExtents);
//设置缩放比例
es = m_pPSV->setUseStandardScale(m_pPlotSettings, Adesk::kFalse);
es = m_pPSV->setCustomPrintScale(m_pPlotSettings, 1, 1);
es = m_pPSV->setPlotCentered(m_pPlotSettings, true);
es = m_pPSV->setPlotCfgName(m_pPlotSettings,m_strDevice);
m_pPSV->refreshLists(m_pPlotSettings);
AcPlPlotEngine* pEngine = NULL;
  if(Acad::eOk == AcPlPlotFactory::createPublishEngine(pEngine))
// 打印进度对话框
AcPlPlotProgressDialog *pPlotProgDlg = acplCreatePlotProgressDialog(acedGetAcadFrame()->m_hWnd,false,1);
AfxMessageBox("打印进度对话框开始...");
pPlotProgDlg->setPlotMsgString(AcPlPlotProgressDialog::kCancelJobBtnMsg,_T("Cancel Job"));
pPlotProgDlg->setPlotMsgString(AcPlPlotProgressDialog::kCancelSheetBtnMsg,_T("Cancel Sheet"));
pPlotProgDlg->setPlotMsgString(AcPlPlotProgressDialog::kSheetSetProgressCaption,_T("Job Progress"));
pPlotProgDlg->setPlotMsgString(AcPlPlotProgressDialog::kSheetProgressCaption,_T("Sheet Progress"));
pPlotProgDlg->setPlotProgressRange(0,100);
pPlotProgDlg->onBeginPlot();
pPlotProgDlg->setIsVisible(true);
es = pEngine->beginPlot(pPlotProgDlg);
AcPlPlotPageInfo pageInfo;
AcPlPlotInfo plotInfo;
// 设置布局
plotInfo.setLayout(m_layoutId);
// 重置参数
plotInfo.setOverrideSettings(m_pPlotSettings);
AcPlPlotInfoValidator validator;
   validator.setMediaMatchingPolicy(AcPlPlotInfoValidator::kMatchEnabled);
es = validator.validate(plotInfo);
// 开始打印
const TCHAR *szDocName = acDocManager->curDocument()->fileName();
es = pEngine->beginDocument(plotInfo, szDocName, NULL, 1, true, m_strPath);
// 给打印机和进度对话框发送消息
pPlotProgDlg->onBeginSheet();
pPlotProgDlg->setSheetProgressRange(0, 100);
pPlotProgDlg->setSheetProgressPos(0);
es = pEngine->beginPage(pageInfo, plotInfo, true);
es = pEngine->beginGenerateGraphics();
es = pEngine->endGenerateGraphics();
es = pEngine->endPage();
pPlotProgDlg->setSheetProgressPos(100);
pPlotProgDlg->onEndSheet();
pPlotProgDlg->setPlotProgressPos(100);
es = pEngine->endDocument();
es = pEngine->endPlot();
pEngine->destroy();
pEngine = NULL;
pPlotProgDlg->destroy();
else
  acedAlert(_T("打印失败!"));
 楼主| 发表于 2013-10-17 16:27:05 | 显示全部楼层
着急中,自已先顶一下。。。
发表于 2013-10-17 18:45:49 | 显示全部楼层
ydp_00769 发表于 2013-10-17 16:27
着急中,自已先顶一下。。。
pPlotProgDlg 的返回值是不是空的?
 楼主| 发表于 2013-10-20 17:21:08 | 显示全部楼层
这个进度对话框是可以不要的,我把关于pPlotProgDlg 的代码都注释掉也不行啊。
发表于 2013-10-20 18:40:44 | 显示全部楼层
能加入es =。。的地方都加入,调试时断点跟踪看看哪里出问题
发表于 2024-7-20 15:33:35 | 显示全部楼层
请问下,如何不使用进度条对话框,直接打印
GMT+8, 2025-5-1 03:19 , Processed in 0.182209 second(s), 24 queries , Gzip On.
