楼主: star_sur
怎样用一条直线按面积比例分割任意形状多边形?想了很久,还是没思路
发表于 2015-12-8 17:24:58 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2015-12-8 17:27:09 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2018-10-19 09:29:53 来自手机 | 显示全部楼层
射线与点表求交点,再用二分法计算面积!这样可行不
发表于 2022-6-22 17:59:42 | 显示全部楼层
(vl-load-com)
(defun ebox (e / pa pb)
         (Vlax-Invoke-Method (Vlax-Ename->Vla-Object e ) 'GetBoundingBox 'pa 'pb )
             (setq pa (trans (vlax-safearray->list pa) 0 1)
                   pb (trans (vlax-safearray->list pb) 0 1)
             (list pa pb)
(defun cbox (e / box)
         (setq box (ebox e))
         (mid (car box) (cadr box))
(defun mid (p1 p2) (mapcar '* '(0.5 0.5 0.5) (mapcar '+ p1 p2)))
(defun mktext (str pt th)
  (entmake (list '(0 . "TEXT")
                 (cons 1 str)
                 (cons 10 pt)
                 (cons 40 th)
                 (cons 11 pt)
                 (cons 71 0)
                 (cons 72 1)
                 (cons 73 2)
(defun str2lst ( str del / pos )
    (if (setq pos (vl-string-search del str))
        (cons (substr str 1 pos) (str2lst (substr str (+ pos 1 (strlen del))) del))
        (list str)
(defun ptscen (Pts / )
  (MAT:vxs (apply 'mapcar (cons '+ pts)) (/ 1.0 (length pts)))
(defun MAT:vxs ( v s )
  (mapcar (function (lambda ( n ) (* n s))) v)
(defun dxf (key ename) (cdr (assoc key (entget ename))))
(defun 2epi ( e1 e2 mode / l r )
    (setq obj1 (vlax-ename->vla-object e1)
            obj2 (vlax-ename->vla-object e2)
            l (vlax-invoke obj1 'intersectwith obj2 mode))
    (repeat (/ (length l) 3)
        (setq r (cons (list (car l) (cadr l) (caddr l)) r)
              l (cdddr l)
    (reverse r)
(defun p2ld (pt p1 p2 / )
  (car (trans (mapcar '- pt p1) 0 (mapcar '- p2 p1)))
(defun gvp (e)
        (vl-remove nil (mapcar '(lambda (x) (if (= (car x) 10) (trans (cdr x) 0 1))) (entget e)))
(defun mkline (pt1 pt2) (entmakex (list '(0 . "LINE") (cons 10 pt1) (cons 11 pt2))))
(defun new_ss (lastobj / ss obj)
  (setq ss (ssadd))
        (setq obj (entnext lastobj))
        (while obj
            (setq ss (ssadd obj ss))
            (setq obj (entnext obj))
ss
(defun ss2lst ( ss / i l )
    (if ss
        (repeat (setq i (sslength ss))
            (setq l (cons (ssname ss (setq i (1- i))) l))
(defun c:tt ( / a angint ar ar1 bang box cont dd dh dx e e0 ee h h1 lm lstr0 m1 n odlst p1 p2 pa pb pc pm pm1 pts ssn str tm w x)
(vl-load-com)
(setq odlst (mapcar 'getvar '("cmdecho" "osmode")))
(mapcar 'setvar '("cmdecho" "osmode") '(0 0))
(setq cont T)
  (while cont
    (setq str (getstring "\n输入面积划分表<800.22,200,330.45...>"))
    (if (/= str "")(setq cont nil))
        (setq lstr0 (mapcar 'atof (str2lst str ","))
                n (apply '+ lstr0)
                e (car (entsel "\n选择多段线:"))
                p1 (getpoint "\n地块划分起点:")
                p2 (getpoint p1 "\n划分方向:")
                bang (angle p1 p2)
                pc (ptscen (gvp e))
                ar (Vlax-Get (Vlax-Ename->Vla-Object e) 'Area )
                lstr0 (mapcar '(lambda(x) (* x (/ ar n))) lstr0)
                lstr0 (reverse (cdr (reverse lstr0)))
                angint (atof (angtos bang 0 4))
                lm nil
                ee (entlast)
        (vl-cmdf "_.rotate" e "" pc (- 90. angint))
        (setq box (ebox e)
                p1 (car box)
                p2 (cadr box)
(mapcar 'set '(w h) (mapcar '- p2 p1))
(vla-copy (vlax-ename->vla-object e))
(setq e0 (entlast))
(entdel e0)
        (foreach a lstr0
        (setq dh (/ a w)
                pa (mapcar '+ p1 (list 0 dh))
                pb (mapcar '+ p1 (list w dh))
                tm (mkline (mapcar '- pa (list 10 0)) (mapcar '+ pb (list 10 0)))
                pts (2epi tm e 0)
                pm (mid (car pts) (last pts))
                pm1 (mapcar '- pm (list 0 (* 0.5 dh)))
        (vl-cmdf "boundary" "a" "b" "n" e tm "" "" pm1 "")
        (setq m1 (entlast)
                ar1 (Vlax-Get (Vlax-Ename->Vla-Object m1) 'Area )
                dx (- a ar1)
                dd (/ dx w 2.)
        (while (not (equal dx 0 1e-3))
        (mapcar 'entdel (list tm m1))
        (setq pa (mapcar '+ pa (list 0 dd))
                pb (mapcar '+ pb (list 0 dd))
                tm (mkline pa pb)
                pts (2epi tm e 0)
        (setq m1 (entlast)
                dx (- a ar1)
                dd (/ (abs dx) w 2.)
        (vl-cmdf "boundary" "a" "b" "n" e tm "" "" (mapcar '+ pm (list 0 (* 0.5 dh))) "")
(mapcar 'entdel (list e tm m1))
(setq e (entlast)
        h1 (abs (p2ld p1 pa pb))
        p1 (mapcar '+ p1 (list 0 h1))
        lm (cons pts lm)
(mapcar '(lambda(x) (mkline (car x) (cadr x))) lm)
(mapcar 'entdel (list e e0))
(setq ssn (new_ss ee))
(vl-cmdf "_.rotate" e0 ssn "" pc (- (- 90. angint)))
(mapcar 'setvar '("cmdecho" "osmode") odlst)
试试看 参考
发表于 2024-4-29 07:06:23 | 显示全部楼层
这个好,但是我想要vba的,
发表于 2024-4-30 15:40:00 | 显示全部楼层
如果要求右边的区域就把直线左边的点都移到直线上,或把直线上的都删掉,剩下的多边型的面积就是你要的了
发表于 2024-4-30 15:41:33 | 显示全部楼层
处理点数组,可以先把多边形克隆到DBXDoc里,这个处理起来非常快
发表于 2024-4-30 15:43:34 | 显示全部楼层
相当于用顶点做一个环形连表,然后在直线左边的都删掉,和直线相交的两点连起来就是了
发表于 2024-4-30 15:44:38 | 显示全部楼层
做个链表类来处理这个
GMT+8, 2025-5-1 05:57 , Processed in 0.158342 second(s), 19 queries , Gzip On.
