查看: 1787|回复: 3
VB统计CAD同名图块数量,请指点错误
发表于 2013-10-14 15:01:11 | 显示全部楼层 |阅读模式
Private Sub 同名图块数量统计_Click()
On Error Resume Next
    Dim returnobj As AcadObject
    Dim basepnt As Variant
    Dim icount, ocount,i
Thisdrawing.Utility.GetEntity returnobj, basepnt, "请选择一个统计对象"
Thisdrawing.SelectionSets("XZJ001").Delete
Set oSSet = Thisdrawing.SelectionSets.Add("XZJ001")
oSSet.SelectOnScreen
icount = 0
ocount = oSSet.count
For i = 0 To ocount
If oSSet(i).Name = returnobj.Name Then icount = icount + 1 ’问题在此,不论条件成立与否,都会执行then后的+1语句,求解
Next i
msgbox icount
oSSet.Delete
End Sub
发表于 2013-11-7 09:40:30 | 显示全部楼层
Private Sub test_Click()
     Dim returnobj As AcadEntity
     Dim mm As AcadEntity
     Dim icount, ocount, i
    ThisDrawing.Utility.GetEntity returnobj, basepnt, "ÇëÑ¡ÔñÒ»¸öͳ¼Æ¶ÔÏó"
    ThisDrawing.SelectionSets("XZJ001").Delete
    Set osset = ThisDrawing.SelectionSets.Add("XZJ001")
    osset.SelectOnScreen
    icount = 0
    ocount = osset.Count
     For Each mm In osset
        If mm.name = returnobj.name Then icount = icount + 1
    Next mm
    MsgBox icount
    osset.Delete
End Sub
验证通过
 楼主| 发表于 2013-11-11 15:42:10 | 显示全部楼层
非常感谢您的回复,对我很有启示,多谢了。就是有点不明白"ÇëÑ¡ÔñÒ»¸öͳ¼Æ¶ÔÏó"是什么意思。
发表于 2013-11-11 18:12:11 | 显示全部楼层
什么意思都不是,就是你的程序里的 "请选择一个统计对象"提示,不知什么原因从VBA拷出来的程序中文都是乱码
GMT+8, 2025-5-26 11:55 , Processed in 0.144510 second(s), 23 queries , Gzip On.
