楼主: jh1005
[源码] 画多段线投影线 v1.2(2024-2-1更新)
发表于 2017-12-12 08:48:07 | 显示全部楼层
非常好用,能加上孔位就好了
发表于 2017-12-13 08:31:20 | 显示全部楼层
厉害。。。。谢谢楼主,下载来备用
发表于 2018-2-1 14:23:30 | 显示全部楼层
感谢分享程序,感谢 jh1005 楼主!
发表于 2018-2-2 14:21:44 | 显示全部楼层
圆好像不行!!
发表于 2018-2-14 04:36:56 | 显示全部楼层
RE: 画多段线投影线 v1.1(2016-8-6更新)
here is one that lets you define a line that points are to be projected upon.
  1. ;project lines - GREAT FOR CREATING ELEVATIONS
  2. (defun pt?  (pt)
  3.   (and (vl-consp pt)
  4.        (= (length pt) 3)
  5.        (vl-every (function (lambda (coord) (= (type coord) 'real)))
  6.      pt)))
  7. (defun C:PROJECT  (/ osm cmd orth p1 p2 p3 p4 Lb sslp lth cont cont1)
  8.   (setq  osm  (getvar "OSMODE")
  9.   cmd  (getvar "CMDECHO")
  10.   orth (getvar "ORTHOMODE")
  11.   sslp (ssadd))
  12.   (setvar "CMDECHO" 0)
  13.   (setvar "ORTHOMODE" 1)
  14.   (setvar "OSMODE" 0)
  15.   (if (and (setq p1 (getpoint "\nFirst point: "))
  16.      (setq p2 (getpoint "\nSecond point: " p1)))
  17.     (progn
  18.       (command "_.LINE" p1 p2 "")
  19.       (setq L (entlast))
  20.       (redraw (entlast) 3)
  21.       (setvar "OSMODE" 33)
  22.       (initget "Erase")
  23.       (setq p3 (getpoint "\n<Enter to exit>/Select point [Erase]: "))
  24.       (if (pt? p3)
  25.   (progn
  26.     (setvar "OSMODE" 0)
  27.     (setq p4 (polar p3 (+ (angle p1 p2) (/ pi 2)) 1))
  28.     (command "_.LINE" p3 (inters p1 p2 p3 p4 nil) "")
  29.     (redraw (entlast) 3)
  30.     (setq sslp (ssadd (entlast) sslp))
  31.     (setvar "OSMODE" 33)))
  32.       (while (or (pt? p3) (= p3 "Erase"))
  33.   (initget "Erase")
  34.   (setq p3
  35.          (getpoint "\n<Enter to exit>/Select point [Erase]: "))
  36.   (if (pt? p3)
  37.     (progn
  38.       (setvar "OSMODE" 0)
  39.       (setq p4 (polar p3 (+ (angle p1 p2) (/ pi 2)) 1))
  40.       (command "_.LINE" p3 (inters p1 p2 p3 p4 nil) "")
  41.       (redraw (entlast) 3)
  42.       (setq sslp (ssadd (entlast) sslp))
  43.       (setvar "OSMODE" 33)))
  44.   (if (and (= p3 "Erase") (ssname sslp 0))
  45.     (progn
  46.       (prompt "\nSelect projection line(s)")
  47.       (setq cont1  0
  48.       lb  (ssget))
  49.       (setq cont 0
  50.       lth  (sslength lb))
  51.       (while (<= cont (- lth 1))
  52.         (if (ssmemb (ssname Lb cont) sslp)
  53.     (progn
  54.       (ssdel (ssname Lb cont) sslp)
  55.       (command "_.ERASE" (ssname Lb cont) "")         (setq account (1+ cont)))
  56.       (setq cont1 (1+ cont1)))))
  57.       (prompt (strcat (itoa lth)
  58.           " Selected object(s)), "
  59.           (itoa cont1)
  60.           " Projection line(s) erased"))))
  61.   (if (and (= p3 "Erase") (null (ssname sslp 0)))
  62.     (prompt "\nProjection line(s) not found to erase")))
  63.       (setvar "OSMODE" osm)
  64.       (setvar "ORTHOMODE" orth)
  65.       (if (ssname sslp 0)
  66.   nil
  67.   (command "_.ERASE" L ""))))
  68.   (setvar "CMDECHO" cmd)
  69.   (princ))
  70. (princ)
发表于 2018-5-3 19:13:42 | 显示全部楼层
只能多段线吗,楼主开发个直线的么!应该很有用!
发表于 2018-5-13 13:22:08 | 显示全部楼层
有创意,赞一个。
发表于 2018-5-27 22:28:19 | 显示全部楼层
能支持直线吧?平时很少多断线啊
发表于 2019-5-22 14:52:28 | 显示全部楼层
不错很好用谢谢楼主!
GMT+8, 2025-5-30 14:22 , Processed in 0.169643 second(s), 20 queries , Gzip On.
