查看: 1256|回复: 0
[运行时] 为什么实体没有闪烁直线没有被被修改
发表于 2013-9-15 15:36:12 | 显示全部楼层 |阅读模式
string Hand = dg_data.Rows[e.RowIndex].Cells[1].Value.ToString();
                using (DocumentLock docLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument())
                    using (Transaction trans = extDatabase.TransactionManager.StartTransaction())
                        try
                            if (LastId != null)
                                Entity Ent = trans.GetObject(LastId, OpenMode.ForWrite) as Entity;
                                Ent.Unhighlight();
                        catch { }
                        long val = Convert.ToInt64(Hand, 16);
                        Handle hCG = new Handle(val);
                        // convert to objectid
                        ObjectId newId = extDatabase.GetObjectId(false, hCG, 0);
                        Entity ent = trans.GetObject(newId, OpenMode.ForWrite) as Entity;
                        if (ent.GetType().Name == "Line")
                            ent.Highlight();
                            ent.ColorIndex = 1;
                            Line line = ent as Line;
                            if (line != null)
                                line.StartPoint = new Point3d(35500.0+val, 25100.0, 0.0);
                                line.EndPoint = new Point3d(36500.0+val, 25100.0, 0.0);
                        }trans.Commit();
这样实体为什么没有没有闪烁,直线的两点也没有被修改
GMT+8, 2025-5-2 15:30 , Processed in 0.154588 second(s), 24 queries , Gzip On.
